Gypsum/Fibreglass Sheathing - Fasteners?
DMurray
Edmonton, Alberta
My lumber supplier recommended 5/8" Glasroc or Densglas sheathing for the exterior walls of my new garage (as opposed to OSB). It appears to be a special type of gypsum, sandwiched between layers of fibreglass.
I see a lot of residential and commercial construction guys are using it around here, especially in new sub-divisions where the houses are packed together like sardines.
The lumber guy said to use the same nails as you would for OSB (2-3/8 ring shank). But I checked the manufacturers spec sheet and it says to use either screws or 1-3/4" hot dipped galvanized nails with 7/16" heads which sound like roofing nails to me. I have a Bostich coil roofing nailer, but coil nails of that size and type don't seem to be commonly available here. Most places only have 1-1/4 coil nails and electro-galvanized, not hot dipped.
Anyone use this stuff before, and if so, how do you recommend fastening it?
Thanks
nadogail
Coronado, CA
IMHO, I would follow the manufacturer's recommendations; unless I had more and better information than those who have experience with the subject.
If I follow the instructions, and the job turns sour, I can avoid taking the blame. On the other hand, if I make changes to the special procedures I have to assume all the responsibility for the outcome.
