HotShoe
Just thought I'd post about my experience in case there are any of you thinking about going this route.
I'm renting a space and will be doing a lot of welding/fab work, etc. so I didn't want to spend a fortune. I love epoxy floors and would gladly invest in the finish if I had more of a showroom environment. Heck, I've designed a warehouse for a collector that had gorgeous maple hardwood flooring. For now I just need something cheap and easy.
I did spend the time grinding the floor down with my local HD's diamond grinder rental. It work beautifully but easily took the whole day to do 1,000 square feet and made a TON of dust. If I was going for a perfect epoxy finish I probably would have spent another day getting it perfect and patching holes but I need to start making money and stop spending it for once.
I bought the xylene based H&C concrete sealer in gull grey. Went on easy and soaked right in. It did dry slight darker than the color swatch. The fumes were very strong and required a respirator but the sealer dried super fast. Of course, it was 95 out so I'm sure anything would have cured fast in that heat.
I don't have any pics yet but it came out great. The old concrete needed two coats to get an even, matte finish. I'll probably go back and add some type of graphic breakup with different colors for a little style. The next day I had the door open and it rained hard. The water just beads right up. I also spilled some coke that cleaned up easy after sitting a day because I hadn't seen it. We'll see how it handles other spills over time. I don't expect it to hold up to gas or break fluid but I'm not worried about it.
Here's the bottom-line, I dropped a hammer 16' down from my scaffold when I was doing the lights. It left a slight mark and I didn't have to have a coronary about a $$$$ finish. I just touched it up with a brush and it was gone. I know it will take a brutal beating being a working space and all I have to do is roll on a touch up and it will look brand new. I wouldn't recommend it for a showroom space or for a "wow" factor but it is worth the money for a working shop. The space I was in previously had a very, very expensive beautiful epoxy finish and I would have an ulcer every time I marked it, which was often. Now I can worry about other things instead of my floor!
