H.F. compressor auto drain kit
bobs409
Pottsville, PA
Anyone have one of these auto drain kits from Harbor Freight and does it work good? Item #46960
I am thinking of installing one as it's a PITA reaching under my 60 gallon compressor to drain it all the time.
I've never had one of these so how does it work? Can you leave the tank full of air on a regular basis by using one of these?
Thoughts and suggestions are appreciated... :beer:
TBD
Didn't work at all for me, I ended up going back to a ball valve and kicking it with my foot when I walk by.
shovel
Port Neches, Texas
Save yourself some trouble. Install an elbow with a quick opening valve that you can operate with the toe of your boot. You'll be a lot more comfortable with that than any failure-prone auto drain device.
JohnFreeman
central nc
I bought one, when I opened it up, it looked cheaper than the normal HF cheap looking junk. I dumped the parts into the extra widgets bin, and installed an elbow and a ball valve. Workee Workee
OccupantRJ
Eastern North Carolina
You can install a normally closed solenoid with an electrical switch at a convenient remote location, and drain it with the push of a button. You can go a step further with a timer to do it for you, with a predetermined amount of blow-off time. Solenoids are plentiful in industrial salvage yards.
RJ
