Hailing from snowy New England
wrenchmaster
Massachusetts
I was wondering what type of floor and footing is required in MA?
I am trying to not have to pour a 4 ft foundation and footing. Can you use
sono tube down to below frost line for each vertical column?
papp101
Is this for a post frame building?
I would Google frost protected monolith foundation. That's what I did for mine, with frost wings.
Sent from my Pixel 2 using Tapatalk
ConCretin
Central Maine
The simplest and most cost effective foundation for a detached structure is a slab with an integral perimeter footing i.e. a thickened edge. As long as your soils drain relatively well, you can just let it 'float' on the frost or you can protect it from frost movement using rigid board insulation. Place the insulation under the slab and extend it out a distance equal to your frost depth around the perimeter. The insulation will retain the natural heat from the ground and keep the frost from getting under the structure.
I have a 28 x32 garage built on a monolithic slab with no insulation up here in Maine and it performs just fine. Give my Guide to Floor Slabs in the link below a read for some additional thoughts on slab construction. Good luck with your build!
kmacht
Connecticut
In my town in CT I was allowed to do a slab with a thickened edge as long as it was detached from the house and under 600 square feet. Anything bigger than that and you had to do frost walls down to 42".
madmikeee
I have an 8" slab that has a 4' deep sill here in MA. Depending on the thickness of the actual slab you MIGHT be able to get away with no footings depending on the load and your local code requirements
