I got a small impact driver, but the torque was not enough to loosen a battery terminal nut that was seized by corrosion salt.
So I put the closed end of a combination wrench on the nut and strike at the open end with a small hammer. It did the trick to loosen the nut.
I was just wondering if there's some way to make striking a wrench easier, as the edge is thinner than the flats and I'm likely to hit my hand instead.
