Hand held blowers
sz0k30
I'm always on Facebook and a lot of various ads & sites always keep popping up. Lately its been small handheld blowers that they show for car drying, amongst other uses. They work on most (Dewalt, Milwaukee, etc) name brand batteries. Any body have any real life experience with these? Do they work or are they just a joke?
Ohio Andy
Columbus, Ohio
I think it was project farm... And they tested Ryobi highly. My brother in law have me an insane amount of Ryobi stuff so I already have lots of their batteries. But not as good as my Milwaukee or festool stuff, but it all seems to work... So I bought a hand drill size blower and it does not disappoint. It rips through m18 batteries, but I really like it.
sz0k30
I have a Mellif? that uses DeWalt batteries- it's great for what it is. For drying a car I use my Ego blower.
I tried to use my EGO leaf blower to dry my car. Problem is: I'm old and have had shoulder issues. That Ego is heavy especially raising it high enough to do the roof, hood & trunk. That's why I'm asking about those mini blowers.
richfinn
Leeds, Yorkshire, England
I've got the wolfbox mini blower, it's great for blowing out spark plug apertures/air filter housings and drying out damp electrical connectors, cleaning car interiors
I doubt you could dry a whole car with it but it charges quite fast via USB C in the van
BombShelter
State of Hockey
I've got a couple Makita's that I've had for eight or so years and they are awesome! Probably not great for drying a car but for blowing grass off the mower, leaves off the deck and my favorite, getting the fire pit going, they are so nice.
Recent uses included blowing out the inside of the furnace to get the dust bunnies out and lightly dusting the garage floor. I'll also use it for baseboard radiator cleaning and I hit the dirty carpet with it to lift up object making it easier to vacuum.
I believe they can **** as well but I never use that feature. These are one of those how did I live without it tools.
KnurledNut
n/a
I have no experience with any of the generic ones, but my Makita 12v is lightweight, powerful and performs well under heavy use.
MileHighRover
This is a phenomenal handheld blower. It has a rubber tip which is perfect for use on a vehicle, in case you bump the paint. If you already have a Ryobi battery, even better, because the 'tool only' is $69.
Ryobi Compact Blower
Ohio Andy
Columbus, Ohio
I bought the Milwaukee 12v and the air output is a bit disappointing.
Yeah I went with the 18 volt and I don't think I would try to use it for my yard, but it works really well. Getting dust out of rafters. Blowing things around the floor. Blowing things off the porch. Blowing things out of my garage. But it eats batteries for lunch.
IndyGarage
Indy
My 36v Makita (18v x 2 batteries) blows harder than my handheld gas Stihl. Not sure what I expected from the Milwaukee, but it's not that useful.
Steve_P
Understand. There's a generic short nozzle on Amazon for some of the Egos that has a rubber end ring and makes it easier to handle. But if its just the weight, then no help. The smaller Mellif? one I have is great but IMO not suitable to dry a car. Yes, its better than nothing. But even the Ego only removes most, not all, of the water.
dscheidt
When I ran a gas station, we had a drive through car wash. It had 2 5 horsepower blowers for drying, on a 60 second cycle. According to the manufacturer, that would remove about 2/3 of the water that an undried car carried away.
Tchicken
THE Motor City
I was caught up in the idea of blow-drying the car, so ended up with two solutions. One was a replacement shortened nozzle for my DeWalt 20V blower. The other a Master Blaster Sidekick made for drying cars and cycles. After fussing with both I don't tend to use either. The short spout on the blower makes it handy to use, but you have to find it and install it. The little Sidekick features a higher airflow plus heat, but is corded so you need to run a wire. Either way it is more bother than just grabbing a drying towel for me. As has already been pointed out blowers don't really completely dry off a car anyway
ALinCarolina
NC Piedmont
After watching the Project Farm post I ordered the Storm Industries blower off Amazon since I have plenty of Milwaukee stuff. Where I wash my vehicles at the shop is on well water so I noticed more spotting after they dry. I had been using a chamois but I was pleasantly surprised on how well the blower cleared off the water. It makes for much quicker chamoising.
I also find it is handy for any quick cleaning like when I open the roll up doors I can blow away any leaves that accumulated at the base.
D.F.B
Australia
Ok, so I've been using blowers for car drying for many years now. I did have a dedicated car drying blower, but the convenience of battery power and the lack of a hose makes a leaf blower a quicker and easier to manage solution.
I started off using a small handheld Makita. With a 5.0 ah battery, I could blow off a large sedan in one charge. A workable solution, but not the most efficient or effective.
I then tried using a mid-level Stihl battery leaf blower. The long tube and lack of grunt meant the little Makita actually worked better.
From here, I went the dedicated blower route. Most certainly this is the most effective way of air drying a vehicle, the way the nozzle tapers increases the air velocity and makes it easier to "drive" water from the surface. If it matters, air is drawn through a filter first, and heated too. But as mentioned, you need to manage both a power cord and hose.
From here, I went the EGO route. No question at all, EGO make the best battery powered blowers money can buy. In fact, the top spec model is the most powerful handheld blower on the market, and that includes petrol powered blowers too. But which EGO blower. Ignore the LB530, it's too lean and the lack of a variable trigger and the lag between squeezing the trigger and the motor spinning is frustratingly slow. The LB615 and LB650 are shrill. The ones to look at are the LB765 and LB880. I also recommend the 4.0 or 5.0 ah battery, the 2.5 ah will do it, but you cut it fine.
Now, that tube length is far too long for this role, or at least to close for comfort for my liking. This is where the stubby nozzle comes into the picture. For a while, the only option here was an aftermarket 3D printed nozzle. However, EGO now make their own with proper injection molded plastic and a release tab. It also comes with a rubber tip to prevent accidental damage if made contact with the car.
Part Number is AST200
If you already have a leaf blower, you can get stubby nozzles for a variety of brands, including Milwaukee, Makita, Ryobi, DeWalt. These are the 3D printed type, but they work just fine. They don't come with a rubber tip, so make sure to order the optional silicone Blower Band as well. If you have an EGO, go with the OEM stubby as it's actually cheaper.
Just keep in mind that you won't totally dry a vehicle with a blower, there will always be a few areas where a towel will be needed to finish things off. That may or may not bother you. Also, you must have a decent wax, sealant or ceramic coating on the vehicle to permit water beading, which in turn allows the air to drive the water off the car. It will also take you a bit of practice to do this efficiently.
Also, ignore those 3D printed mini blowers that you see heavily advertised on social media and sold via Amazon. They look impressive for the brief demos shown in the ads, but they just don't have the capacity to do a complete job.
MileHighRover
...Also, you must have a decent wax, sealant or ceramic coating on the vehicle to permit water beading, which in turn allows the air to drive the water off the car...
This is the most important part of blow drying a vehicle. If you don't have a well maintained paint finish with a really good coating on it, blow drying isn't going to work.
KnurledNut
n/a
@D.F.B
What an awesome helpful post from real experience.
Always refreshing when a post is bumped with something worth reading.
(y) (y)
D.F.B
Australia
To expand on this a little more........................
- The idea is to create a barrier between the paint and the water, which in effect rejects the water and causes it to bead or sheet. These beads are then easily blown from the paint, glass and plastic.
- A ceramic coating will be the most effective here. In that I mean a proper ceramic coating applied from a small glass bottle, think Gyeon Pure EVO, Carpro Cquartz, Armour Detail Supply Quartz. You do need to be experienced to apply these, or have it professionally installed.
- Having said that, a traditional wax or sealant, a ceramic spray sealant, or even good spray wax will work. While not quite as hydrophobic as a coating, these are still a workable situation. For wax, look at Collinite 845, a good sealant would be Jescar PowerLock Plus, something like Carpro Reload or Adam's Slick & Slide for a spray sealant, or Optimum Car Wax is a ****** brilliant spray wax.
- If you are lazy and want something quick and easy, then grab a product like Gyeon Wet Coat, Carpro Hydr02 Lite or 303 Spray & Rinse Sealant. These are applied while the car is wet after washing. Working panel to panel, apply a few sprays to the surface and rinse immediately. Continue working around the car until done. The stream of water activates the sealant and distributes it across the surface. These don't last as long as the other methods listed above, but they are quick and easy that reapplying is not all that much of a chore.
I use these when I have a customer's car that has completely flat/dead water behaviour. This does two things, adds some gloss and slickness, and makes it quicker/easier for me to dry the car...............time is money and all that. They are also brilliant for wheels, coating the barrel and brake caliper without having to remove the wheel.
D.F.B
Australia
I will also use a blower after cleaning engine bays.
Using the blower does two things -
- Removes excess or pooled water
- Helps distribute a very mild dressing application without having to mess about with brushes and towels
The above is a reset type engine bay cleaning, hence foaming first.
As with all cleaning though, frequency is the key, so quite often a superficial rinse and blow dry is all you need.
sz0k30
Thanks for the great writeup!
shoot summ
I have 2 Dewalt 20v, the jobsite model, and the larger model. They work, but to get it done quickly and thoroughly nothing beats the Stihl BR600.
JerseyJeff
Great write up! Very helpful to those looking to move to the next steps.
GirlnAgarage
Texas
Well I just impulse purchased an Ego LB880 because if yall.
Actually needed one. Came w 2 4ah batteries which will match great with the Ego string trimmer I bought this summer. This blower was also on sale. So if yall thinking bout it, now might be the time. I can't wait to go try it out.
D.F.B
Australia
For anyone looking at the EGO LB-880, which is the latest and most powerful unit before stepping into the commercial range, battery selection is very important.
To achieve the maximum output, the minimum battery size on the 880 is the 4.0 ah battery, with a preference for the 5.0 ah. The unit will still run on the smaller and lighter 2.5 ah, but EGO have programed it to go into a reduced output when paired with the small battery. I'd say this is done to prevent over-drawing and therefore overheating the smaller battery. Heat kills batteries, both in terms of charge, but also longevity.
Git
S Cal
Actually, the BR800 does :)
I saw that ACME Tools had a sale on Stihl, and looked into the different models. I pulled the trigger on the 800, but when I entered my shipping info - they wouldn't ship to California :(
When it comes to cordless blowers, I am all in on Makita. (the one with the bag is a blower/vac)
GirlnAgarage
Texas
I ran the 880 today to clean up the front and rear porches plus the big pad in front of the shop. I am impressed at the power and the run time of the 4ah battery. I didn't time it but for the area I covered, I used half a battery. I probably would have used the whole battery if I blew out the shop too. I'll measure the sqft for an idea.
I liked the variable trigger. The ergos were comfortable but I did get tired of holding the blower forward to combat the force. I put the shoulder ******** and it was comfortable. I laughed as I blew off the porch mats....they blew away and the large 4x5 started flapping around like Aladdin's magic carpet getting ready to take off. I didn't expect that. So be careful. Don't blow away your wife's favorite porch things. I did not try the wide mouth or the funnel yet but I'll get around to it. So far A+ for the 880. If you're on the fence - buy.
mike93lx
Richmond, VA
I have two ego blowers, the biggest backpack from about 4 years ago and I think the biggest handheld from around the same time.
They are great for clearing dry leaves off the driveway and patio, but I'd never want to be stuck with either for moving any real amount of leaves. Run time on turbo with a 7.5 is only about 15 min
Steve_P
I have 4 medium and three large deciduous trees and do leaves with the Ego. I do have two 4AH and one 5AH batteries though. As I said, it has more power than my gas handheld Echo. I do not need to use the turbo setting. I'm not doing leaves after 2" of rain but they are often damp.
