Hand tools
Status
Not open for further replies.
Yoji
For hand tools which do you recommend I get more of wrenches or sockets or extensions or adapters or ratchets? I will later on go through all my tools and tell you everything I have and then see what you guys recommend what else I should get. Should I buy some power tools and air compressor? Even though I have my dad's power tools and air compressor at the house if I wanted to have my own tools.
Fedwrench
Valley of the sun
Welcome to the journal:beer:
It depends on your budget, what tasks you're performing and what you're working on. Are we talking automotive tasks?
If so, I'd start out with a shallow 3/8 drive metric set 8-22 mm. If you have a need for SAE, add a set from 3/8-7/8. Add combination wrenches in the same size range. I'd add a 1/2 drive breaker bar that's at least 18 inches long and a 1/2 female by 3/8 male adapter so you can use your 3/8 sockets with the breaker bar. Ratchets are a slippery slope. However, I'd start out with the longest 3/8 drive fixed head ratchet I can find. The Quinn comfort grip 90 tooth ratchet is pretty handy and inexpensive. You can add flex head ratchets in varying lengths later. a three-piece set of extensions in 3-6-10 inch lengths are handy. I'd also recommend a compact 1/4 drive set like this Kobalt set that is very handy too.
You can add 1/2 drive stuff as the need for larger sizes/more oomph arises.
An air compressor is a substantial investment in coin, space, and noise but, is definitely worth it in the long run. Cordless tools on sale are a smart investment that you can grow a little at a time. There's a bare bones, budget friendly, start. Need to know what your goal is to give a better answer. Visit the Tekton.com website to get more ideas. Good luck in your quest :beer:
Y
Yoji
Thank you so very much for your help
I have most of the socket sizes that you've listed and I think I have some of the combination wrenches you've mentioned
lardy1
If I was looking to start a tool collection I would look into Tekton also. The quality for price is quite attractive and they now have a fairly broad range of tools unless you are getting into specialty work. Gearwrench is another common option. Harbor Freight is well known for their budget pricing but I suggest you ask around before blindly purchasing from them. They have come a long ways in their quality but still handle some low quality items. There are a lot of decent tool brands out there so expect to be overwhelmed if you do a lot of research. You started on the right foot by asking for suggestions. I wish you well. Buying tools is usually a fun experience. Don't expect to get it right every time.
Y
Yoji
I will go through all my sockets and everything else once I get the chance after I buy more socket clips for the socket rails I have and I will get it complete list of everything that I have and then see what other things you guys recommend even though you all have gave me some good recommendations already and then I will show you all the other tools
Y
Yoji
Pretty much all the tools I have are hand me downs so which some of those were missing some tools so I bought some to fill up one of the tools sets that had tools missing and then I got a free tool set a few years ago for my birthday that still has everything remaining
AEAdam
SE PA
I've written lists here before. We really should have an automotive tool list sticky. My advice is that you find a community college automotive program tool list and use that as your guide.
Note @Yoji, that you didn't answer the question regarding what you intend to do with your tools. Garbage in garbage out. Tell us what you intend to do, want to do and we can provide better responses. Also, your location can make a difference.
Regarding power tools, I think the quick answer is no. I would buy impact sockets and a very long ratchet or breaker bar initially. Depending what you are doing specifically (lawnmower repair? automotive? heavy equipment?) that might be fine. I think a lot of us started with air tools. Many of us still use them. But an awful lot of us also use or prefer cordless impacts etc.
Y
Yoji
It's just for at home use working on vehicles and then I will look into the automotive community college tool list and I live in Memphis Tennessee
AEAdam
SE PA
Thanks for answering the questions:
Here's some more specific advice that may help:
Below is a chart I made of the different hex bolt head standards. You can look at the standard organization your car will most likely fall within and be able to predict what tool sizes you will need. Note that Korean cars may follow the Japanese std, even tho they are not made in Japan. I included std torques to help you determine drive size compatibility. For reference, the torque shown should be roughly half that of the drive's capability.
For Snap On:
1/4" Drive = 90ftbs
3/8" Drive = 250ftlbs
1/2" Drive = 750ftlbs
Example: A Snap On 1/4" dr socket set includes sockets from 5-15mm. On a JIS car, 14mm on a 1/4" ratchet is really going to be fine. An M10 bolt, with a 14mm head in the top strength category 12.9 (pretty unlikely) tops out at 63ftlbs which is well within 1/4" drive range. That same socket fits the M12 12pt flanged bolt and could push the limits of 1/4" drive in the highest bolt grade (111 ftlbs).
Recommend you download this jpg to your computer. You (all) have my permission to print it as you see fit. I think its helpful to have a copy of this in your toolbox.
On "skips":
You will notice our socket sets contain sizes not found on the chart above. 9mm and 11mm come to mind. It may be the case that sockets/tools missing from your set(s) may not need to replaced immediately.
Many here advise having "no skips". That eventually, "you will need the in-between sizes". Example: 9mm and 11mm are the brake bleeders on the Mercedes GLS and Dodge Durango. But you don't necessarily need 9 and 11mm tools in every blessed tool set you own. I have brake bleeder wrenches in those sizes and have subsequently never needed any of my sockets or combination wrenches in those sizes. So take the whole GJ "no-skip" mafia with a huge grain of salt. The concept is fine in my opinion, but the implementation can be expensive.
The best thing to do is get a Snap-on catalog and study it. Don't look at your cell phone no more. Throw it out.
I don't know if this was serious or not. I read it as teasing. But having thought about it, I think this is a really good idea.
Snap On is famous for selling tool sets that "skip" certain sizes. If a size doesn't come in a Snap On set, that might be an indicator you may find little use for that size. I wouldn't buy Snap On because they give you fewer sockets or throw away sockets that come in sets you purchase, but maybe just be cognizant that you aren't paying for tools you don't really need and won't really use. The sizes over 19mm can be the ones to focus on. Those larger sockets can be expensive regardless of who makes them.
The other interesting thing about the Snap on catalog is they will specify the application for certain tools such as "for GM head bolts 2009-2017". Or triple squares "For Porsche Audi". This can be really helpful information not easily found elsewhere.
The other helpful thing to have which you can make yourself is a metric to std conversion chart. Again, my Dodge Durango has 11mm socket head cap screws (Allens) for brake caliper bolts. I went out and bought an 11mm Allen bit socket, which didn't come in my set (stopped at 10mm). 11mm = (approx) 7/16". It's possible those bolts are really 7/16" and not 11mm at all. I probably had a 7/16" Allen bit socket but assumed it was a metric vehicle. Anyway, good to have a chart.
Point is, a basic tool list won't cover any of this. As a first step, I think you can look at what I posted and think about what you are missing based on what you will most likely encounter the need for.
The other point I would make is, my personal approach is to know what I need, tools, parts, equipment, processes, consumables, torque specs, etc before starting a job. "Having everything" is expensive and often unnecessary (not to mention inefficient due to storage/accessibility requirements). "Wait and see what you need" or "Buy as you encounter the need" for me, results in my buying tools readily available to me and either paying too much for them, or getting poor quality (mostly both) because that was all my local auto parts store offered.
Top drawer of my automotive tool box has a lot of tools and only a few sets of basic hex sockets (Far left). The remaining 2/3rds of the drawer is comprised of specialty sockets, bits sockets, ratchets and extension collected over a lifetime of (mostly German) car repairs. Try not to get lost in one sort of tool (sockets for example). That's why a community college tool list can help. And this is just one drawer.
richfinn
Leeds, Yorkshire, England
Home use, just buy the wrench/socket sizes and depths required for your personal vehicles in the best quality you can currently afford.
If your cars are metric or SAE buy those sizes first.
There are lots of high quality affordable brands online/Amazon
Facom 440 Wrenches
Vessel Megadora Screwdrivers
Ko-ken sockets and accessories
Hultafors hammers
Knipex pliers
Uni-T multimeters
Stay clear of the tool trucks for basics or at least until you are working as a pro mechanic!!!!
Robinson1
Kentucky
Totally depends on what you’re working on.
For me at least I want a complete set of 3/8” drive standard and deep, metric and SAE. For metric I’d consider a complete set to be 8mm to 19mm and SAE from 3/8 to 3/4. Many sets go past 3/4”/19mm but for what I usually work on 19mm is usually where I switch to 1/2” drive.
Cover that first and make sure you have wrenches to match the socket sizes. No matter what you’re working on this will be your core set of hand tools.
You can get by with about any 1/4” set as it’s all low torque applications. I’m not saying buy the cheapest set you can find but in all reality a Walmart set will serve you fine unless you’re a pro using them 8 hours a day everyday
1/2” just buy impacts and you can probably get by with only buying deeps. Again depending on what you’re working on you may not need a particularly large set but I think most people will find use for sockets in the 13 to 24mm range. Mine go to 36. And on the SAE side stopping at 1-1/8 is fine unless you’re working on equipment. You’ll find a lot of 15/16 and 1-1/8” on structural fasteners
Y
Yoji
Here's everything that I have
76 bits
19 piece auto trim removal tool kit
Adjustable 15mm wrench
3/8 combination wrench
7/16 combination wrench
1/2 combination wrench
9/16 combination wrench
5/8 combination wrench
8mm and 9mm ratching combination wrench
10mm combination wrench
12mm combination wrench
13mm combination wrench
14mm combination wrench
15mm combination wrench
Driver for sockets
3/8 drive ratchets
1/4 drive ratchets
3/8 drive sockets and extensions and adapter
3in extensions
All of my sockets are shallow unless spark plug sockets
7/16
3/8
3/4
11/16
5/8
14mm
16mm
13mm
3/8 to 1/4 adapter
5/8 spark plug socket
13/16 spark plug socket
10mm
15mm
14mm
9mm
11mm
19mm
17mm
1/4 sockets and extension
4in extension
3/16
5/32
7/32
1/4
9/32
5/16
11/32
3/8
6mm
13mm
11mm
5mm
15/32
4mm
4.5mm
9mm
7mm
1/2
7/16
10mm
12mm
8mm
5.5mm
Fantikk Nex S1 Pro Cordless Screwdriver Kit that come the 16 bits
Hammer
Phillips head screwdriver
Flathead screwdriver
Need to get 1/4 or 3/8 9/16 because that's a socket that's missing from one of the tool cases I threw away
AEAdam
SE PA
This is very hard to read. We don’t care how many you have of each. If you want, please edit to say something like “3/8” dr shallow sockets, 7-10, 13,15mm”
From what I can see, you are missing some essentials
Y
Yoji
I edited it
csp
Franktown, CO
If you don't know what you need how are strangers supposed to know? Everybody's tools/uses/needs are different.
Y
Yoji
76 bits
Driver for sockets
3/8 drive ratchets
1/4 drive ratchets
3in extensions
7/16
3/8
3/4
11/16
5/8
14mm
16mm
13mm
3/8 to 1/4 adapter
10mm
15mm
14mm
9mm
11mm
19mm
17mm
4in extension
3/16
5/32
7/32
1/4
9/32
5/16
11/32
3/8
6mm
13mm
11mm
5mm
15/32
4mm
4.5mm
9mm
7mm
1/2
7/16
10mm
12mm
8mm
5.5mm
Hammer
What other sizes for wrenches and sockets and extensions and ratchets and adapters would you guys recommend?
AEAdam
SE PA
Print out the chart I posted. Use highlighters to color in what tools you have in each size. Color code one color for wrenches, and a different color for each drive size. Then you will be able to visually see what you are missing and how the missing tools will most likely impact your ability to repair a vehicle of a given make.
Y
Yoji
Thank you so very much for mentioning that
Y
Yoji
Or if I want to go crazy as possible what would you guys think about getting the gearwrench megamod 1268?
AEAdam
SE PA
I think crazy is the operative word. Like all “master mechanic sets” you probably would never use half those tools. 1) It’s a full set of SAE tools. Do you need that? 2) It’s 12pt sockets in every drive size. Do you need that? 3) 1/4” impacts? And no impact guns? Just why.
My advice. Start with a small roll cart like this one. This is a Snap On KRSC32A and a bit smaller than the HF cart. The standard HF 5 drawer cart is really big enough.
I arranged this cart differently than pros do. The top well is really a catch all, storing torque wrenches, lights, workshop manuals, prybars a dead blow hammer etc. Sockets wrenches and screwdrivers are in the drawers.
Here’s the socket drawer
Top left Torx bit set. Going down the left hand side side:
Deep 6pt 3/8” dr metric
Shallow 6pt 3/8” dr metric
Shallow 6pt 1/4” drive metric,
red MTS holder 6pt 3/8” dr SAE (Craftsman, everything else is Snap On).
Middle top:
SAE Allen bit sockets (red holder - HINT cover is still on indicating how infrequently I use these)
3/8” metric shallow swivel sockets (green MTS holder)
3/8” metric Allen bit sockets, assorted types (green MTS)
Random 3/8” dr 21mm socket. Forget why I needed that.
1/4” dr metric allens
Right:
Basic second hand ratchets and extensions, a couple misc long torx bits.
NOTE: I chose the Mechanic Time Savers (MTS) magnetic socket holders for certain sets of tools I often remove to use. The swivel sockets are the exception. When I’m working on my lawnmower, I just grab that set of sockets and stick it to the mower frame. Same with the Allens. I often guess wrong at the Allen sizes, so I just grab them all.
Screwdrivers and pliers
The ratchet screwdriver set at middle, is pretty special and not an absolute necessity. That said, I use it pretty frequently as a 1/4” socket nut runner and to remove T25 and T30 body and air dam fasteners. Not a necessity, but nice to have for sure.
Only notables here are the oil filter tools (strap wrench and pliers) and the cable hose clamp tool, all of which belong in every automotive tool box.
One more thing to note: I don’t have or need 50 pairs of pliers. What’s not in this box may be more useful info than what is.
Bottom drawer holds wrenches and impacts
Those are 25 yr old craftsman impacts. I have only a single 6” extension. I bought the gun second hand for about $300. It’s kind of a beast, tbh. I’d prefer a smaller mid torque gun, but if you can only have one, it should probably be a high torque model.
Lurking in the bottom of the picture is the Snap On SHLF80A ratchet. This is an absolute must have. It has a fine toothed head, a 26” long handle and is as strong as a breaker bar. I use it one almost every job. Obviously, I just put my impact sockets on it. I have no 1/2” chrome in this box.
This is far from a perfect set of tools. My main box is bigger and has a bigger selection of tools. But due to the convenience of this box, my ability to pull it outside on a nice day for example, I have found myself tackling fairly significant jobs using only these tools.
I hope this gives you a look at what a basic set of auto repair tools might look like. There are a few tools I could live without in this box. There are a few jobs the tools in this box probably couldn’t tackle. But for most jobs, these simple, good quality tools are often sufficient.
Y
Yoji
Where would you guys recommend find individual tools or tool sets? Or which route should I go?
BlakeTheCarGuy
Roanoke Virginia
I like a lot of different brands for tools. For individuals I usually go Tekton, Capri, Kobalt, Craftsman, Husky or my really preferred brands are Carlyle, Power Torque, Duralast or DieHard because the parts stores have come a very long way with tools and I like shopping in store. You mentioned being in Memphis so I know you have some AutoZone stores there. But there are so many good brands these days you can’t really go wrong with any of them. I say that from a professional mechanic standpoint. I buy from tool trucks too but more so in stores and am just as happy with tools from stores.
Bubba Fett
Eastern NC
My advice: Get the best tools you can afford, but don't put yourself in a financial hole. Snap-on is great, but you'll end up in debt with them for years, if not decades if you are not careful.
Nothing wrong with Harbor Freight if you are just starting out. Ignore all the "brands" they have. Turn the package over and look for country of origin. Anything made in Taiwan will be higher quality than anything made in China (as a rule of thumb). The same applies to brands typical retail brands like Craftsman, etc. However, brands such as Gearwrench are mostly made in China, but are still good quality.
As you use tools, you'll begin to want something better. For example, you may want nicer ratchets, pliers, or screwdrivers. Generally, the tools that hold in your hand on a daily basis will be the ones you'll want to upgrade. The ones that get used occasionally will be fine unless there is a quality issue.
If you want pro-level tools, consider industrial brands, such as Proto, Williams, and Wright. These are often near/at/or even above the Tool Truck brand quality, but for less money. For example, you could splurge on a Snap-On ratchet, but get Williams or Proto sockets, and still have a top-level set.
Y
Yoji
And to fully get the wrench sizes to fully max out both SAE and metric wrench trays I'm going to get 11mm combination wrench and then 16mm to 23mm combination wrenches and then I'm going to get 5/16 and 3/4 and 13/16 and 7/8 and 15/16 and 1 and then 1 and 1 1/8 and then 1 1/4 and then 1 5/16 and then 1 3/8
I have been DIYing for over 55 years, which means I have been acquiring tools for that long.
The first question you need to answer is "Do I need imperial/SAE wrenches/sockets ?" Amazingly, I still use my "inch" sockets and wrench even today ! Mostly on older yard equipment. If you won't be working on that, you likely will not need any of them !
  • You will need both 1/4" and 3/8" sockets (including ratchets, extension and universals) AND combination wrenches. For sockets, only buy 6 point sockets ! You will not need 1/4" deep socket, but you will need 3/8" deep sockets.
  • Air tools for DIYers are dying fast ! Buy name brand battery tools. If you want to save money, only buy 3/8" impact sockets.
  • Notice, I did NOT mention 1/2" drive sockets. The only thing I use them for is lug nuts. Buy accordingly. (All of my 1/2" drive stuff is in the bottom drawer. I have not used most of it for years.)
  • When you have some extra money, buy double ended, long pattern, box end wrenches.
AEAdam
SE PA
Hopefully you are tracking. Buying an 11mm combination wrench to complete a set is a waste of money. There are no std 11mm bolt heads you will encounter. Don’t buy tools to fix unicorns.
As @theoldwizard1 rightly mentioned, be careful spending on SAE wrenches. Here’s my take: Since I bought Snap On wrenches, I’ve really grown to love using wrenches. If you intend to work on cars, buy decent wrenches. I don’t care for HF, but the HF icon wrenches are pretty awesome for the money. I’d skip cheap wrenches altogether.
Fill in only the missing metric sockets and only those on the chart. Then buy a set of Torx bit sockets, a decent set of wrenches, then start tearing into some vehicle repairs. The rest you will figure out. But I’d be very surprised if in a years time you didn’t have a roll cart that looked just like mine.
I bought most of my Craftsman tools pre-1990 so they are all made in the USA. I was able to pick up some inexpensive, used Craftsman stuff (made in the USA) in the early 2000s. Too many people now think they are "collectable" and want ridiculous money for them.
If you really want to save a buck, you have to shop garage sale and estate sales.
FigN⋅m
I use my 11mm's to cross over to 7/16" surprisingly often (for my use case)
A good chunk of the USA-made platform racks we install utilize 7/16" hardware
and the 11mm also fits my Picquic Dash 7 shank which is 7/16" for some reason, eh?
ecotec
I, absolutely, agree. Estate sales and garage sales have allowed me to build a far better collection of tools than I could ever justify if they were at retail prices.
There is tonnage of tools out there. There is very little reason to pay much for the most common tools.
Spend the majority of your tool budget on what you can’t find cheap.
f121
UK
11mm is often used for fine thread m6 on euro/uk stuff.
f121
UK
Guessing you don’t do suspension work on trucks, SUV’s or even large sedans?
L.Cheapo
When I was starting out 30 years ago, I spent money on the things that were always in my hands: ratchets and a ratcheting screwdriver. Those were Snap On hard handle(personal preference), and I still use them to this day.
Everything else was Craftsman USA at the time. Today you don't really have that option, but you do have Tekton, Harbor Freight's brand du jour, a few others, and whatever your local home improvement and auto parts stores sell.
Buy what you need to do what you can now. It's amazing how much you can get done with just the basics. I did it for a long time. As your skills and the breadth of what you work on grows, so will your tool collection. Be patient, and save money for when you do eventually need something expensive.
AEAdam
SE PA
Right!
I bought an awful lot of Snap On stuff on eBay for less than 50% of list. I think there are deals to be had on whatever you want that is mass produced. Even Porsche 911s can be had for a small fraction of their original asking price.
The only tricks are knowing what to look for and being patient. Hopefully this thread is a step in the right direction for someone starting out.
I really wanted Craftsman long DBE metrics. Picked them up piece meal on eBay. Paid too much, but I got them !
AEAdam
SE PA
I bought my brother the craftsman professional “fully polished” combination wrenches which were made by the old SK. They probably wouldn’t fare well against modern competitors but they were beautiful wrenches. They had beautifully flared ends. I think SK put a lot of pride into those wrenches. The chrome was supposed to be special as well I think. They could have been the first of the craftsman fully polished tools in the 80s.
Y
Yoji
That's nice to know but you never know nowadays compared to older days of tools how they would compare to each other if you get what I mean
Y
Yoji
So what I forgot to mention is there is one socket that I'm missing from a tool set that I got as a hand me down which had a bunch of other sockets missing that I already replaced and the same thing for wrenches but there's only one socket that I need which is at 9/16 should I get it in a shallow or deep and what about 1/4 or 3/8 drive?
Status
