Hand-Tow Handle for Cart
Rarified27
Between PA and NJ
I'm just about done building my own yard cart out of plywood, door hinges (for dumping) and some HF caster wheels, but need something sturdier than the one linked below to haul everything from dirt to rocks and even some old flagstone I need to remove from the property.
http://www.harborfreight.com/swivel-handle-for-wooden-dolly-94354.html
I don't expect much for $6.99, but that handle will snap with the load I'd need to move around.
If there is a proper name for this type of handle, that may also be why I can't find anything online.
Can anyone recommend an online or brick/mortar supplier to find something solid?
Thanks!
astroracer
Mid_Michigan
For 7 bucks get it and try it. The weak link will be how it is fastened to your cart. Through bolts will solve that problem. Steel tubing in tension is far, far stronger then any stress you will ever be able to put on it. :)
Mark
77Ford
Picked one up and for moving my Toughsystem boxes around the garage on Dollies .....I think this is the ticket. Thanks OP I did not know they even made it.
DeWalt.......love me some "Yellow" [emoji12]
