Handle Dip for pliers and the like?
lbhsbz
Long Beach CA
Years ago, I remember my Dad had a can of plasti-dip that clearly showed pliers being dipped in the material to make new handle grips. This is what the stuff was originally for and as I remember it, it left you with a handle about like what you see on a channelock brand plier.
The stuff that exists today is about worthless in that respect, and I think more geared around being used as a paint type coating on cars/wheels etc.
Does anyone know of a product that will create good handle grips? I was thinking of trying FlexSeal (not the spray).
ihateminimumwage
The current Plasti-Dip is actually still really good, but you have to be very patient and dip it a few times. Did a bunch of older Williams and Proto Los Angeles pliers maybe 4 years ago, and they've held up great to shop use and abuse. Nothing has come off, and they've been so filthy and greasy the handles looked black, but have cleaned off good as new with a rag and gas or diesel (whatever is around).
I taped my handles to the level I wanted them, dipped and hung from wire to dry a few times, cut through the new grips to the line where the tape was and removed it, and than dipped one more time so it would have a clean taper.
Picture of not too long after I dipped them. I'm not at work so can't get a current pic until next week (if I remember :D)
gdocktor3
Connecticut
Those look factory. Nice job. I quickly sprayed plastidip on an adjustable wrench I found on the ground. It was pitted and covered in rust. After I freed up the adjusting gear, I decided to spray it. While it was rushed and looks crappy, it's held up for almost a year now. I just wanted to see if it would actually work.
L
lbhsbz
Long Beach CA
I've not impressed with the current plasti-dip...it's absolutely nothing like the plasticine OE grips.
Superbec
Netherlands
I'm looking for a solution like this for quite a while
I want to coat the claws of the tire machine so it dosn't damage motorcycle wheels .
Plastic inserts that came with the machine are ****, I used different kind of tapes with various results (res-q tape, self vulcanizing rubber , and some other sorts)
Laast time I had a left over tube of sikaflex and smeared it all over the place, it held up for a 50-100 tires but now it's disintegrating.
I ordered a PU set that should be just the thing for this, it's a bit pricey and not that easy to use , I just didn't had time for it lately.
Know Wosad
I have a roll of " Channellock blue" shrink tube sitting in front of me that I'm thinking about.My thought was to leave the bottom 5/8 or so of each leg"nekked". I think it would look cool PLUS no way any moisture would get trapped inside. My tools wind up in solvents quite a bit.That kills that problem, should it try to happen.Shrink tube is basically indestructible too.
CutterFarms
Kentucky
Those look really good. I thought about trying that but I've never seen it in red. All they stock at several different stores in my area is yellow. Did you have to special order it to get it in that color?
Coach James
Sandhills of North Carolina
I did several pairs of pliers in red. I got it at Lowes I think. I went very slow at the rate given in the directions on the can, hung to dry then repeated. It has held up well. I will try to post a couple pics later today. I really don't expect it to hold up as well as a factory handle.
Coach
tonyprovo723
I was just looking for something like this the other day. Except it was for a whistle. Finger Grip Referee Whistle. I needed to coat the finger portion and the mouth piece. The spray from plasti-dip was too thin a coating and looked to be too big a mess to mask off. Actually dipping would of filled it with plastic making it useless. I settled on a bunch of coats of liquid - tape electrical tape. I used black and it had a nice gloss to it. Worked good. We'll have see how it holds up.
Sent from my SM-G920V using Tapatalk
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Is that the stuff that Phil Swift advertises on TV? If so, I think I would give that a try. By the way it looks when they pour it into a pan and it cures into a sheet of rubber, looks fairly impressive. I'd like to try a can myself for various applications.
ihateminimumwage
I can't remember where I picked it up from. You may want to check your local stores again, they use the same can for all the colors (with the yellow pliers on the front), but have a colored "dot" sticker on the top of the lid that identifies what color is actually in the can.
It's annoying because they always seem to be on a low shelf in a space just tall enough to slide them in, so you can't see the top without pulling each can out (I'm looking at you, HF):lol_hitti
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
I use PlastiDip on some of my factory-style restorations (wiring clips, dash board retainers, etc.) and, being out in the sticks, order it from CaswellPlating.com. It's about $12, lasts a long time, and can be thinned with naptha if needed. Here's a set of my Commando valve covers with wire guides finished in PlastiDip.
Coach James
Any tool of mine that needs the grips replaced now gets double wall adhesive shrink tubing. I tried plasti-dip on a couple tools and it was just too much of a hassle for my liking. It would probably work better if you wanted to do a bunch of tools at a time. Multiple coats were always required, the smell was strong, they had surface imperfections no matter how careful I was, it left a porous flat sheen surface that always looked dirty, etc. My plasti-dip container also dried out on its' own (within 1-2 months) as soon as more than 20% of the dip was gone, even though the lid was closed the whole time. As a result, I just got tired of hassling with it.
I have a pair of Proto 11" high leverage diagonal cutters that came from the factory with very thin semi-translucent red handle dip (I could see through it) for some reason. Instead of exchanging them I added a second layer of black adhesive heat shrink to the handles. They are now nice and comfortable during use and the heat shrink is holding up very well. If you get double wall thickness tubing with a 3 or 4 to 1 shrink ratio, and then buy tubing that is larger than needed (just to fit over the handles), you can get nice thick handles with only one layer of heat shrink because the more it shrinks down the thicker the wall of the tubing becomes. Having the adhesive inside also eliminates slipping and/or liquid penetration issues. I left mine short by about a half inch at the handle ends and that works just fine. If you want to try it out for yourself, cut your pieces a little bit long because the heat shrink will shorten some as it shrinks.
I'm thinking of also getting a small assortment of colored adhesive heat shrink tubing so I can cut small rings and put them on all my custom modified and/or specialty pliers to more easily identify them visually from my regular pliers in my plier drawers.
I'm not a big fan of coated handles in general on my most used tools. I find them to be too slippery when my hands are greasy or wet, or else they are a hassle to keep clean (textured Knipex grips). I can tolerate slipperiness related to my chrome ratchet handles, but not for my pliers. I now only leave the original dipped handles on my lesser used hand tools, and/or on any tools that I never use around grease or liquids. I also leave the dipped handles intact if the bare handles would end up too thin to be comfortable during use. Almost everything else gets stripped bare and modified. After stripping them bare I smooth the forging seams out with a flap wheel on my angle grinder, and then I add a little bit of DIY surface cross hatching to provide good grip under all conditions without tearing or catching nitrile gloves. I make the cross hatch texture by simply scraping across the metal surface with the side of a 14tpi bimetal hacksaw blade. When finished, I give the metal a quick coating of rust preventative and that's it. Good to go for a lifetime and it makes the tools basically bulletproof. I no longer need to hassle with cracking handle ends, handles that want to slip off the tool, melting handles around torches or welders or soldering irons, no slippery handles when wet, no more bulky handles in tight work areas, its' easy to instantly identify my tools when working with others, etc.
Here is a picture of my Proto long diagonal cutters with shrink handles, as well as a couple pictures of some of my bare handled tools.
Did you use a wire wheel on those bare handles?
Coach
413dan
Massachusetts
Decade bump. Anyone got any new products they recommend or go to's on this topic? I've got a a few old pairs of channelocks and other oddities I'd like to potentially add new grips to. Color not a big deal. thanks
Steve_P
Lots of threads on this. Plasti dip is like Krylon in comparison to modern automotive paint. It looks just as good until you use it or expose it to the elements.
There are some universal grips that you can glue on or maybe heat shrink.
Schurkey
I dipped some pliers handles decades ago. Around 1987-ish.
I was so disappointed in the results that I never bought Plasti-Dip again. The handles ended-up with a uselessly-soft coating that deformed with hand-pressure and picked-up dirt that couldn't be cleaned-off.
