Handling Heavy tire/Wheels
Skyking1992
I do most of my own vehicle maintenance, including tire rotations. No Problems for most vehicles including my wifes Chevy Impala with 20 inch wheels. But I recently bought a new GMC 2500 truck with 20 inch rims and I can't handle the rims/tires easily. I must be getting old. So what are you guys using to handle heavier rim/wheel combinations? I've seen some rigs with rollers, but I don't want something that takes up a huge amount of room in the shop.
Thanks in adance for all your help.
BillK
Beautiful Southern Maryland
It takes a little longer but when I do my Tahoe I just use my floor jack and get the weight just barely off the tire and then pull it off. Then I will put a jack stand under that position. Then roll the tire to the next spot and repeat. I use the floor jack to get the axle lined up with the wheel and slide it on. I do not have a lift.
WildBill
PNW
I don't know what it's called but my brother uses a deal the looks kinda like a small handtruck frame with wheels on the back. It hangs on the wall when not in use. You tilt it to lift or lower the tire. Not very big and is really light.
Fixr
SW VA
A cheap handtruck might just do the job.
jsaw
Geneva, N.Y.
I started out lifting them with a big pry bar, but it was a bit of work because the tire would roll off the bar.
I took some scrap pieces of conduit and made a tire lifter
Skyking1992
Thanks guys, you are giving me some ideas. I do have a two post lift. Today I did oil and filter change, grease 9 zirks, rotate tires, and reset TPMS. I was exhausted when I got done rotating (and torqueing to 140 ft lbs) tires. I did lower truck and used a prybar. In the old days, I would have just grabbed the tire and lifted it chest high! Again - I think I'm getting too old for this.
Fixr
SW VA
I don't have room to store another single-purpose special tool, so I think I'm going to try out one of my regular hand trucks next time. If I remember.
Thanks guys, you are giving me some ideas. I do have a two post lift. Today I did oil and filter change, grease 9 zirks, rotate tires, and reset TPMS. I was exhausted when I got done rotating (and torqueing to 140 ft lbs) tires. I did lower truck and used a prybar. In the old days, I would have just grabbed the tire and lifted it chest high! Again - I think I'm getting too old wise for this.
FTFY
jsaw
Geneva, N.Y.
FTFY
I tried using a hand truck. It seemed too awkward to Me
junkyardwarrior
did tractors for the first 29 years of working career. THey had nothing to lift those big heavy things onto the hub. Just had to creatively lift the tractor to the wheel and line it up. Pain in the....back, neck, arms, legs, everything.
heaven forbid one show up with tires filled with fluid. 1000lbs each in a lot of cases. Need helpers just to keep it from falling on you. Boss never thought nothing of it.
Fixr
SW VA
It would be a compromise for me, not as good as a dedicated tire lift with rollers, but a whole lot better than just my back.
jayemm
up high down low
I was thinking about sliding the tire on a shovel and working the handle to adjust height. However it may be one of those thought experiments that sounds better than it works. Guess I'll find out next month at tire rotation time.
finn
The UP, God's country
This and a long pry bar between the concrete and tire to finesse the tire and wheel a ssembly over the wheel stud.
The pry bar gives you leverage to deal with the weight.
CraigStu
Blacksburg, Va
I am thinking of a prybar made of something like a 1x6 or 1x8 for the portion under the tire w/ a 2-3ft handle extending outward. I 'think' you could put the tire on it and the width would allow you to roll the tire a bit to either side to fine tune the rotation to line up lugs. You could swing the handle portion left and right also to line up lugs.
txvwnut
Bedford, Texas
^^^^This right here, work smarter not harder. I have two lifts and still do my truck tires this way.
At the day job I was doing tires once and one of the other techs decided he'd help me. His *** was 6'4" and I'm 5'11" so he decides to run the lift to its max height. I said congratulations you just inherited this job and walked off. He replies I was just coming to help not take over, I replied you ever seen me lift 60 pounds of tire/wheel up that high. He realized his mistake and set the lift back down to where I had it. After we were done he said even having to bend down it was easier to do than lifting them 5 feet up.
Crabman
Alexandria, VA/Dameron, MD
Same problem on weight, 50 lbs. the new 100 lbs.
Cheap solution. Use chair on wheels, get tire in lap, roll over and mount tire. Need lift height to match lap height.
Or cheaper hydraulic solution.
Go for maybe $199 on sale. Depending on what you have, can park under workbench maybe to save floor space.
Good luck finding a solution to a depressing problem.
finn
A regular Wilde or Methew 2’ long bar works, although sometimes I use my grandfather’s 5’ steel bar.
The Chinese HF bars aren’t as stiff as the Wilde, (or whoever) domestic bars, so there’s a lot more flex lifting a tire. But they do work.
I’ve lifted 19.5 “ tires on an F450 with no issues, once you develop a technique. The big split rim 20” F600 tires on my dump truck were best installed with the side of the 5’ bar.
cannuck
Rural SK
I do everything up to 11R 24.5 on my semi with 2 ordinary pry bars. You need 2 for stability and the need to rotate a bit to align studs. Of course at 73 I am quite a bit younger than some of us here, so I guess why I find it so easy. The little stuff on cars and vans I just use my toe to lift.
Higgins
Shepheardsville, KY
Ask the boss to show you how to take the tire off!
dante2
Central OK
I got one of the double scissor lift carts from Vevor. It lifts 330lbs up to 50 inches. I got two 10in rollers on to it so I can roll the tire to line it up. Rollers are put up until I need them. We have 2 vehicles with tires on the back and I won't need to pick them up any more with this cart.
Skyking1992
Thank you all. The Redline Tire Dolly is exactly what I was looking for. I do enough work that I think that will be well worth the cost. I knew I could count on this group to have all the answers.
KEH
7.50 x 20 8 ply front ribbed tractor tire. The tractor does have a FEL so that helped. Parked my utility trailer close, lowered ramp. Got wheel off, rolled it up the ramp on the trailer. Took it to tire store, bought new tires and tube. (ouch!) Brought them home. Adjust jack height, used shovel as described in above posts to help line up a couple of lug bolts. Got nuts on and the other lugs lined up as the lug nuts on the first two were tightened.
KEH
