My basement is set up as a home gym. As I expand it, I have wanted to add a mirror for some time now and finally got a free mirror from CL. It's a 4'X4' and its from a bathroom. What is the best way to hang this? It's pretty heavy.
I agree, making a frame for it would be the right way to do it. Those Tapcon screws work quite well in concrete, never tried one on a block wall, but I imagine it would work just fine.Frame it and use French cleat system. You can get metal cleat sets at Home Depot. Use Blue-Tap concrete screws.
I don't know if it's right or wrong, hopefully somebody here can clarify for both of us but I was taught when you drill/screw into a block wall always try for a mortar joint.
I am the owner of a glass company. I have been a glazier for over 40 years.
Simple enough to hang with a J-bar and a couple mirror clips but if you are putting a 16 square foot mirror on the wall in a home gym you need to use mirror mastic as well. here is the why on that.
A mirror hung with only mechanical attachments in a gym are very likely to get broken some time in their useful life. If mastic is used as designed a broken mirror remains on the wall until it is safely repaired/replaced. Without mastic it will possibly come off the wall and the possibility of serious and even fatal injuries are real.
Mirrors hung using mirror mastic must also use a load bearing support at the base as well as a anti tilt "clip" on the sides or top.
If you are not inclined to glue the mirror to the wall and would like to use clips or a frame yet still retain a safe installation, have the mirror safety backed. Safety backing can be applied at any local glass shop that has safety backing in stock.
We apply it for $3.50 a square foot. Safety backed mirror can still brake but will remain in one piece thus preventing the chances of injury.
