Hanging an air filter from ceiling
Whiskeymike
Austin, TX
I'm making a shop air filter from a large squirrel cage and motor, some filters and a sheet metal box I'm fabbing. I'm trying to figure out the best way to hang it from the ceiling. I have ribs above to connect to. I could do uni strut or home made equivalent, all thread, chain, ???. Any thoughts on the best way?
CNGsaves
KS and OK
My neighbor had one of those nice woodworking air filters and he attached with unistrut with some threaded rod to lower it a bit.
That's what I'd recommend.
readhead
Durango, Co.
All thread. What are you hanging it from? You mention ribs. Wood, steel? If it is a metal building and you are hanging from the purlins be sure to attach to the side, not the bottom flange. Also try to stay as close to a frame as possible.
gregtwojeeps
Ky
When the blower kicks on, there will be some pretty good "twisting" action going on with it ....hanging from chains. JMO
zkdiesel
chicagoland cornfields
Sliding barn door track anchored to ceiling, then used barn door wheels to connect to my air filter and modified a cord real to hang heavy electric to it in the middle. Have a 2x2x6 air filter hanging in ceiling that slides 40' side to side to get closer to area that needs filtering
W
Whiskeymike
Austin, TX
Metal building, 2 pieces of c channel run length wise of building about 4' apart. Thanks for the tip of going into the side. I was going to go into the bottom, but can see how that would be bad.
shoot summ
Unistrut across joists, hooks on one end going into loops on the dust unit so it can hang while I connect the all thread on the other end.
rsanter
visalia ca
How tall is your ceiling?
In a previous house I was doing a lot of woodworking in the garage.
I also had limited ceiling height. What my plan was to put it in the attic right above the garage.
Since you are building it anyway I would mount the fan in the attic with ducting going to the garage ceiling for inlet and outlet
Bob
Git
S Cal
The Jet air filter I have comes with 4 eye bolts for chains OR it has 4 metal brackets that you can use to screw it directly to the ceiling when you remove the eye bolts.
I wanted mine up as high as I could so I used the metal brackets. In this pic you can see two the holes where they attach to the metal frame near the eye bolt
https://www.amazon.com/dp/B00004R9LO/?tag=atomicindus08-20
machsnell
Northern Virginia
I wonder if that can be mounted vertically into attic with ducting back into garage? Where is infrared eye? Side or front?
turbowoodworker
Apex NC
I have a jet and a delta, neither of which are homemade, and I just used lag type eye screws. The commercial units have such low horsepower that they do not move at all on chains.
W
Whiskeymike
Austin, TX
Bob
It's a 14' peak, but it's a metal building, so no attic. I'd like it to be pretty high though. The chains seem like a cool option.
Thumper68
Duluth MN
My home built one hangs from chains and eye bolts, a bit of a shake on startup part of which is the tug on the switch chain but other wise it just hangs there 16 feet off the floor.
