bookman51
I am planning to hang some drywall over some insulation and behind where cabinets will go in my pole building--just to 4 feet up and above that white pegboard. The building will only be heated occasionally and not quickly or all that warm--probably overhead radiant electric heat. The temperature in the building can range from well below zero in the winter to over 100 in the summer here in Nebraska. Do I need to leave any gaps in the drywell for expansion or is it going to crack--whatever I do?
In the more exposed parts where I am not having cabinets I plan to hang one sheet of plywood to four feet up (and paint it white) so I can hang stuff on it--unless someone has a better ideas. Not sure what thickness I will use. I will put pegboard above the plywood too.
Bookman
Bookman
Other than the mudding and sanding of joints on drywall, I prefer it over OSB just for the smoothness. The only other thing is finding the studs when you want to hang something, but that is not that huge of deal either.
