Rockuf8
Almost done with the drywall and mud in my garage and I will be reattaching my cabinets and add more as well. Previously I marked my height, drew a level line, installed/attached a 1x2 support screwed into every stud 16" OC on my desired line height, rested my cabinets on top of the 1x2's, and predrilled holes that matched up to the studs in the top and bottom of the cabinet where the 1x4's (or equivalent) are.
I left the 1x2's underneath as added support, but was wondering if I went for a cleaner look if I could remove the 1x2's and still have the cabinets hold the same weight I threw into them the past 6-7 years, which was a decent amount.
I guess I could always fill the holes and paint the 1x2's same color as the wall and they would disappear. Just wanted to find out what most of you guys usually do in this case when hanging pre made (kitchen/laundry room) style cabinets. The reason I was going to leave them in place was I wanted to use the tops of 5-6 cabinets to store extra wood trim (bb, chair rail, crown..etc) to get it out of the way since some pieces exceed 10ft in length. Previously, I had them stored on plywood shelving mounted on steel shelf brackets screwed into the studs with lag bolts, my guess is the weight was easily 100-150lbs worth of trim. I'm not using the steel shelves and am hoping the cabinets will be able to hold the weight.
