Hi. I'm looking for ideas for cheap garage shelves for rubbermaid boxes, etc. I'm thinking 2x4 ledgers on wall and then tie into ceiling. Basically a big box attached to a wall and then the ceiling. Add some simple 1/8" plywood/mdf in a sliding channel for the door (cosmetic/dust protection).
I've searched the forum pretty hard w/o luck.
Can anyone share any design ideas / pics?
Thanks, Brad
Here 'ya go, Here's Jack's overhead cabinets with sliding doors in grooves cut on his table saw:
The grooves:
I'd suggest you make your shelves out of a simple "ladder" type frame lag bolted to your wall studs. 2x4's would work fine but I'd prefer using 2x6's so you have the space under them to mount simple (and cheap) "can" type lights that will wash your walls and/or light the bench tops you place below.
An example of that is here:
Here are the canned lights washing below:
Finally, you mention simply attaching these cabinets to the "ceiling" so I assume your garage HAS a ceiling? Or did you just mean attaching the cabinet "upward"? Because if that's what you meant, someone here (sorry, I didn't save your name) came up with a simple, cheap, strong and ingenious method by using Unistruts lagged into his roof rafters and hung all thread rod downward to hold up ...well, whatever he wanted to hold up. This could work for you. Please post whatever you ultimately decide to do WITH PICTURES, as you can see I like them!
