Dragster Racer
I heat my 40X40 insulated shop, and need to push my propane usage down a bit. I set it at 45 normally and kick it up to low 50's when I am out there. I have a hangine Reznor heater that is quite old.
I have caught this heater when it cycles making a rushing noise, which I would guess means the burner is firing oddly, probably due to being dirty. So I can clean and try to adjust it to see if that helps.
However, I have yet to see efficiency ratings for hanging heaters like they do with home furnaces. I don't know if figuring it is as simple and dividing the output btu number by the input btu number.
I was just wondering if there are hanging heaters on the market now that are higher efficiency than what the old ones tend to be. i don't know if the radients are actually any higher efficiency, but I could go that way if the savings was worth it.
What do you guys know on this?
