Hanging signs from ceiling or from trusses
Gillespie85
Central IL
I collect old gas station related signs. I would like to hang them from the ceiling or trusses in my new pole building.
Anyone have any experience with this? I am worried about the potential weight load on the bottom of the truss.
Thoughts?
Shootinok
Oklahoma USA
Check, if you can, with the truss manufacture. They should be able to tell you the load rating on the bottom cord. Some are designed to support a ceiling, i.e. sheeting or sheetrock. If you have no ceiling, that load potential would be still available.
How big are these signs?
G
Gillespie85
Central IL
sign size varies, can range from 30" to 72". and usually weigh between 20-80 pounds each.
attaching a picture as an example... this is not my building in particular, just showing what i will be doing kind of
ubbthreads.php
G
Gillespie85
Central IL
Thanks... I'm an active member of OldGas already and know most of those guys personally.
I think this forum is the better place for this particular question
GMCGarage
Thoughts?
Dont exceed the load rating of your truss. Use some common sense too.
mcbassin
ubbthreads.php
Wow!
