I have a pole building (40x40x14) that has a flat interior ceiling. Have not decided what material I am going to use for the ceiling(metal, osb, drywal).
I will probably go with 4 ft led fixtures.
My questions are:
1. Did you screw your lights through the ceiling material directly into the truss? (trusses are 4 ft apart)
2. Are you lights flush mount or hanging from the ceiling?
3. Did you do any framing to support the lights?
4. How did you run the electric cable to the lights? Above the finished ceiling or below it?
5. Did you mount any outlet/junction boxes for your lights?
6. Any special consideration for a metal liner panel ceiling?
Thanks
My questions are:
Thanks
