Hantek 1008c advice pls
troikacarleton
Uk
Hi
Got a Hantek 1008c 8 channel
Mostly know how it works, but
1. Can I rig it to show engine ignition timing eg connect Ch1 to the crank Sensor and Ch2 to the Nr 1 spark plug using HC25 inductive connector and get two separated signals on the screen
2. Hantek tell me that the digital output is not supported. Can I use it to display numbers instead of waves. Has anyone a wiring diagram for its connector?
Many thanks
James
lbhsbz
Long Beach CA
A scope measures voltage. you can measure 8 different circuits at once with that scope.
The problem with measuring ignition timing is knowing exactly where TDC lies on the crank position sensor signal...
Typically, you will see a number value associated with the waveform signal on the side of the screen.
