I recently installed a GarageDeck floor from Bigfloors.com. GarageDeck from what I can gather is also made by Snaplock Industries and is a private label brand for Bigfloors.com. They also sell Racedeck and a variety of similar products. I went with GarageDeck as it was less expensive but seems to have the same quality as Racedeck. The AccuPark wheel stops also integrate into GarageDeck and the entire product line I believe.
On the one side of the garage where the edge is exposed, I used the 3" edge pieces (same ones you use at the entrance) to give a finished look. On the other side I cut the pieces to fit with a jigsaw. One thing to keep in mind when ordering- when installed there is approximately a 1/16th gap between the tiles, when you are talking the width of a 2 car garage this adds over an inch. I thought my installation would fit without any cutting but forgot about that factor.
Also after reading comments here and others, I put down a layer of foam underlayment that you would use for Pergo or any floating floor to add cushion and quiet it. That seems to work well. I went to Home Depot and got the cheapest one they had at about .25/sf.
) and there is no sign of anything happening to the concrete ( no paint or epoxy on it) and really not much else...maybe a little dusty. BTW- popping out a single tile or large section takes just a few minutes, so even if you spilled a bucket of oil and left it there for days, you can easily get to it ( unlike carpet in your home)
