Harbor Freight 1/2" Impact....Not impressed
Black_Z28
Well, I went with what a lot of guys said on this forum, and got a Harbor Freight Earthquake 1/2" impact. I must say I'm very unimpressed with this thing. I have it hooked up to a 60 gal 3HP Puma with a Ingersoll Rand regulator and filter, set at 90psi. This is ran through a 3/8" flexzilla hose. So, I assume I'm getting plenty of air to the tool. But, I'm having issues with removing pretty lightly torqued lug nuts and nuts. It was having issues taking lugnuts off my truck that are torqued to 120 ft lbs. I used my ridgid 20v cordless impact and it took it off with no issues. This is the second impact I got from Harbor Freight. I returned the first one, because I thought it was a dud, and they happily exchanged it. Do I possibly have another dud....or was I just thinking this tool was going to be much better then it truly is?
I also got one of the Husky 1/2" that was on black Friday last year that also came with the 25' hose...and I would say they seem to have about the same amount of power.
Any help would be great.
c4cruiser
Lacey WA
Is the compressor capable of higher air pressure? Try something like 125-130psi and see if that works. You may find that 90psi may not be enough.
With my Kobalt (IR) 1/2' drive impact wrench and air pressure at 140psi, I can easily loosed the lug nuts on my Silverado that are torqued to 140 ft-lbs.
dnschmidt
Phoenix, AZ
Your suppose to have 90 PSI at the tool WITH THE TRIGGER PULLED. You're probably losing 30 psig between the regulator and the tool. Take the tool over to the regulator and pull the trigger THEN set the regulator to 90 psi with the tool running. A lot of people make this mistake. Where this really matters is with HVLP spray guns.
I use to have this 1/2" Earthquake and it's amazing for the dough. I now have Aircats because they are quieter but from the performance angle the Earthquake was fine.
organ
Atlanta
I like to set mine at 300 PSI... :3gears:
GSteg
Earth
Yep, need 90 psi at the tool under at wide open throttle. 90 psi at the regulator will choke it, even more so since the Earthquake tends to need more air than other guns.
Black_Z28
Wow, thank you for that information. I honestly never knew that. You guys are great. Learn something knew every day.
blackedout12v
something is a miss for sure. dana 80 pinion nut torqued to 450lb,and my earthquke 1/2 hammered it of there pretty good imo. dont get me wrong it didnt zing it off there but it did take it off around 100lb air pressure. double check to make sure your gauge on the regulator is accurate also. hopefully adjusting the air when triggered will fix your problem. anyways hope you get it figured out
blackedout12v
also the forward, reverse switch may be a issue. unlikely since you have had problems with two seperate guns. im leaning toward a air issue.maybe try it on someone elses compressor if possible.
dnschmidt
Phoenix, AZ
As a former NASCAR tire changer (1979) I can tell you that 300 PSIG is exactly where we had the regulators on the nitrogen bottles used for the air wrenches set. I-R gave us the Thundergun wrenches so we didn't care if they blew up. I did blow one up and they fixed it for free at Daytona so all was good.
jonti48310
We use the EarthQuake as the go to gun in the shopat school. Works very well. I've seen it take loose stuff that the Matco impact couldn't move.
Scimmia
Even that isn't really a good test, since it doesn't account for the drop of the fittings and hose.
90 PSI static off the tank is way too low.
Vegaman_Dan
Pacific, WA
I never knew the air pressure should be set with the tool at wide open. This alone has made the thread valuable to me.
fourtythree
WV
For what it's worth, my Earthquake wasn't worth a damn until I switched to high flow fittings and cranked the compressor up to 120+ PSI. After that, it was a beast.
bob15
Northeasten, CT
What diameter hoses are you running? 1/4" ain't gonna cut it.
Re-read the first post again. I read 3/8" flexzilla.
As for the 1/4 fittings, though not the best out there, will work fine with an impact. More garages and companies (factories) in the country use 1/4 hose ends than anything other size combined.
A 1/2 drive impact with 1/4" quick-disconnects should be able to break-free a lug nut on a pick-up without any issues, even with a regulator set at 90 psi. If it cannot, junk the gun and buy a higher quality impact.
As for the 30 psi loss....not even close. Probably closer to 5 psi.
http://www.productionproducts.com/charts_pressure_loss_hoses.htm
azhatchback
My IR Ti rips lugs off my truck with no issues on a 50ft 3/8 hose, on a 25ft 1/2 inch copper condensation trap with motor guard toilet paper filter, with a 3ft pigtail going to condensation trap, on a small but strong IR GARAGE MATE 20 gal vertical V cylinder compressor set at 90 psi with out tool flowing. All my fittings are 1/4 gold fittings from HF. Maybe you have a bad gauge. That HF gun looks like a sunex re-brand. I bet its a good gun. I like Sunex products but i do own the Ti max.
After painting with compressor set at 40 psi flowing for max cfm, I ran my IR on lugs and it didn't sound snappy but still yanked the lugs off my truck :dunno:
Scimmia
I beg to differ. A good 1/2" impact will use 30+ CFM while actually running. Based on that, you'd drop over 10 PSI from a 25 ft hose, plus the drop from the fittings. Best case scenario, 30 PSI might be high, but it's far more than 5. If, as has been suggested here, the Earthquake takes more air than other wrenches, this number goes up even more. Even more so if a 50 ft hose is involved (OP didn't specify).
stage20
pcola FL
i always read "do not exceed 90psi" so ive never set my pressure higher. ive got an 80 gallon tank. not sure if more volume changes pressure drop. havent had an issue with my earthquake. it twists lug nuts off like it should and nice and quiet compared to my older IR.
redwrench60
East Tennessee
Take that air regulator off and throw it over your left shoulder. You won't overfeed any air tools with that compressor. Screw your air hose directly into the tank fitting for best performance.
bob15
Northeasten, CT
A 1/2" dr earthquake has a rating of 6 cfm (their 1" drive is 10 cfm). A Proto is 4.4 cfm and a snap on MG725 is 5.2 cfm. Where in the hell are you getting 30 cfm from a 1/2" drive impact? We are talking impact guns, not die grinders.
As for air drop....are you saying the the companies that sell air products are lying when they say pressure drop ratings are with 20 cfm flowing through a 3/8 hose at 100 psi is less than 5 psi?
Read what the the pressure drops are:
http://www.airtx.com/recommended-air-hoses.htm
And maybe read what IR has to say as well about your grossly overboard cfm idea:
http://www.ingersollrandproducts.com/am-en/solutions/garage-solutions/maximum-impact-enewsletter/tool-tips/tool-tip-choosing-the-right-air-compressor-consider-power-and-storage-needs
The OP should check the air filter and the gauge on the regulator. The hose and fitting will work fine for removing a lug nut with a torque of 120 ft/lbs.
jethrob
I bought one, threw it away. Didn't have the heart to sell it to someone else.
redwrench60
East Tennessee
Just for giggles I installed a Tee fitting and a pressure guage at my air coupler at work to see what the difference in my static vs dynamic (at rest and under use) air pressures are.
With my IR 2235 timax at rest the deadhead line pressure in the shop is about 160 psi. With the impact running at full throttle free speed the air pressure drops off to 85-95 psi (the guage dances around some) That's a big difference and this is with a large commercial rotary screw air compressor, two 100 gallon air tanks, large diameter copper piping and 3/8" air hoses.
Pressure drops with air flow.
bob15
Northeasten, CT
I've done similar test using the regulator/gauge set-up from my hvlp gun and found the drop was minimal. I've seen places with 60,000-80,000 gallons of compressed air and seen 60 gallons of air and didn't see pressure drops of significance at either place.
If your test is accurate, how is it that every hose manufacturer, air tool company, compressor manufacturer, etc. doesn't agree with your test results? How do factories around the world survive building stuff with 1/4 fittings and 3/8 hoses? From your test, if the reg was set at 90 psi, you would have only 30 psi at your gun.....that i doubt.
redwrench60
East Tennessee
Just sharing my actual personal experience. Pressure drops with flow. If you set a regulator to 90 psi with the impact at rest it will be a gutless turd under full throttle load. Try it for yourself.
fury9
Mchenry, IlLaHnoYs
Dumb question but did you oil the tool good? My gun works awesome and I'm in the rust belt.Just did a rear carrier on a 03 escape, had to loosen a lot of rusted suspension parts. Only had trouble with one and after a minute or two of hammering on it with the impact it broke free. Have my pressure set at 100psi at the regulator then it goes through about 20' of black pipe to my hose reel with 50' of 3/8 hose going through 1/4 fittings.
blackedout12v
only if regulator, line , or fittings aren't capable of the flow required to run the impact.
redwrench60
East Tennessee
Lol, so...pressure doesn't drop with flow? Better go try it for yourself. Trust me, the setup I use at work is plenty adequate and then some. At 90 psi static pressure it's a noticeable drop in performance.
87FoRunner
Memphissippi
FWIW, my snap one didn't work worth a fudge until I oiled them well and ran them a while.
I never knew air tools to need "broken in," but shrug.
redwrench60
East Tennessee
Why don't you kick the training wheels off that scooter. Take that regulator and throw it over your left shoulder and see what real power is like.
It takes a hell of a setup to over feed an impact and most fall short of the recomended 90 psi at the tool at no load wide open throttle free speed.
Red996
This thread is too much about fittings and air pressure. With regular fittings and 90 psi you shouldn't have any problem removing a properly torqued lug nut on any passenger vehicle. I don't think harbor freight has great quality control. They're cranking tools out as cheaply as possible, wider tolerances, fewer inspections. Even if it's a good design there's a chance you got a defective unit. I'd try to exchange it.
redwrench60
East Tennessee
The OP did exchange it once with the same result and I'm not trying to be a smart *** but this thread is about air pressure because that's what the OP's problem is. Probably nothing wrong with his impact, he just needs to feed that thing!
Scimmia
Those numbers are average CFM at some duty cycle, not actual numbers while running. Check Snap-on's website again, the list the MG725 at 37 SCFM.
I was going by the link that you posted: http://www.productionproducts.com/charts_pressure_loss_hoses.htm
Using the 90 PSI chart, of course, since that's the number the OP was using.
Don't come up with different links now just because your first one doesn't support your argument.
This link is a very, very simplified explanation for newbies. Again, it all goes back to duty cycle.
Ruger_556
The average air consumption specs are entirely meaningless, the at load spec is the one that matters. IR's 1/2 gun uses 20 CFM at load. A 1" gun uses almost 50CFM...
Why do people regulate their compressors down? Most homeowners compressors aren't even capable of putting out what our shop air is regulated to.
