So are you saying even if it was torqueing all the studs to 110 ft lb instead of 100 foot pound they would still be even?All you're doing is attaching wheels. Make sure the surface is free of corrosion, and the wheel pulls in flush. Even if the torque wrench was wildly inconsistent, which I've seen no evidence they are, we're talking about an M12 or M14 stud and nut.
I have a hard time believing that a person using a normal sized wrench without extensions could accidentally use enough force to warp an iron brake rotor. I am excluding intentional misuse of tools and gross negligence.So are you saying even if it was torqueing all the studs to 110 ft lb instead of 100 foot pound they would still be even?
I know a lot of people say the actual torque ( I mean within reason)
Is not as important as tightening it evenly, as far as any chance of warping rotors or hubs.
I mean I know I have just tightened up wheels a lot of times with an impact ,(not gotten crazy with it now, as I feel I have a pretty good feel for it,)
Or just tightened them with a breaker bar on my own cars and have not had any problems.
(I always tightened in a star pattern)
I started using torque sticks and torque wrenches more on customers cars than my own just hopefully to avoid problems.
But when I brought this car the rotors were real bad the front ones I've never drove a car that shook so bad on breaking.
I didn't have none of my tools to change the rotors myself so I had to have a garage do it and the braking is perfect.
I just thought I'd get a torque wrench to hopefully keep everything even and not over torqued and especially not to chance warping the rotors.
Again I feel I have a pretty good feel for tightening them evenly but I just want to make sure.
I understand what you are saying. I don't know I know everywhere you read they say in proper tightening can cause warpage, and I have read especially uneven torqueing.I have a hard time believing that a person using a normal sized wrench without extensions could accidentally use enough force to warp an iron brake rotor. I am excluding intentional misuse of tools and gross negligence.
Maybe some rust jacking could cause such a problem if it happened unevenly across the hub face? I don't know for sure since that isn't a problem I see much down here.
Honestly on my street cars I just use an electric impact judiciously and on my track cars I run them down with the impact and tighten with a mid-length half inch ratchet.
Well a missing stud is both pretty obvious and pretty egregious. I would only drive a car missing a lugnut far enough to resolve the situation and no further. I am thinking about with everything present and is decent condition and a normal person making an attempt to be even.I understand what you are saying. I don't know I know everywhere you read they say in proper tightening can cause warpage, and I have read especially uneven torqueing.
I know when I first got that car, as I stated I never had a car that shook so bad on braking.
And it had one of the front studs missing I had it replaced.
Now surely one missing stud would cause uneven torque.
Now why exactly those rotors were so warped I do not know.
Like I said on my own cars I've tightened them plenty of times with just an impact or just a breaker bar and haven't had any problems.
I'm just a little bit OCD and I want to continue not having problems.
I can’t speak to automotive work, but I was told in my oilfield days that even, consistent torquing of all your breaks/connections is more important than hitting the actual specified number dead nuts.So are you saying even if it was torqueing all the studs to 110 ft lb instead of 100 foot pound they would still be even?
yesUsing the torque adapter as a torque wrench with a breaker bar or ratchet you mean?
Normally I would agree with you,while i know nothing specifically about PI brand torq wrenches, it looks as if all their models are easily affordable and usa made (best i can tell). considering those two things ,why even bother with HF ? im betting youll use it for much more than just lug nuts.
Thank you.Autozone has a $15 beam style. No setting or zeroing just tighten until the needle points where you want it. Perfect for things like lugs.
I have the same problem with mine on occasion. I used to set it to a lower torque value than I needed and make sure it clicked before tightening down what I cared about.I must have gotten a dud because I used that torque wrench pictured and twisted off a bolt because it didn't click. From then on I stopped trusting any HF torque wrench. I have the 1/4" version too and it seemed to be right but I couldn't trust how long it would be right. I replaced it as well.
Well, with the beam style you would have to bend the pointer (which would bother someone with as bad of a case of OCD as I've got) but if you can handle that, sure why not?
One of the things I don' like about the PI split beams is that the "click", or whatever the hell that is, isn't very loud or easily felt as the lower torque settings. Mid-range and above no problem, below that you've got to be paying close attention to determine when it's snapped over.
That very true about the PI split beams. Low side is more of a thud than click.
Get a half inch beam type wrench. So long as it's not bent, the handle is not broken or packed with crud, and the needle centers when there's no torque, it's good. If the needle doesn't center, vent it back.I must have gotten a dud because I used that torque wrench pictured and twisted off a bolt because it didn't click. From then on I stopped trusting any HF torque wrench. I have the 1/4" version too and it seemed to be right but I couldn't trust how long it would be right. I replaced it as well.
Your old Craftsman beam style torque wrench has a lifetime warranty if they still make them. Only torque wrench that has thatdnschmidt
This got me thinking. Do you think this would dial in my ancient Craftsman beam style for simple tasks like lug nuts?
I am not building space ships, airplanes, etc.
Thanks, Bruce
if you already own the HF then just clamp something in a vise and hang a wt. to test it at the torque you want - 100 ft. lbs = 50 lbs at 2 ft from the fastener, etc.
if you don't own the HF then buy a CDI or PI or something real
Something they failed to mention is exercising the spring.Torque Wrench Storage and Things to Know About Torque Wrenches
Tips about how store your torque wrenches, how to set them accurately, things to do to extend the life of your tools and other safety tips.www.ultratorq.com
why not? you can get them calibrated and honestly theirs nothing that mechanically complex in a torque wrenchI won't touch a cheap chinese/taiwanese torque wrench. If you need to use one, then it tells me that what you're tightening needs to be precise. I have a mix of Armstrong, Proto, and Precision Instruments torque wrenches.
A. Because I don't trust them to be accurate, nor do I want to have to keep having them tested to feel comfortable with them.why not? you can get them calibrated and honestly theirs nothing that mechanically complex in a torque wrench
