Harbor freight 10” sliding miter saw
90zcar
I picked up this 10” sliding compound miter saw for $85 bucks with a coupon. Has awesome reviews. My old delta 10” miter saw wasn’t able to miter 45* on larger baseboard trim so I needed the capability of the sliding.
Anyways can someone tell me what these 2 screws are for or what each one does. I understand one is probably for depth if you don’t want to cut completely through but why is there 2 side by side.
tarbellb
Oregon
I believe the black screw is for full blade depth stop, ie how far past the base and into the slot the blade will dip. Make sure not to bottom out the blade on the base housing, ideally set at just below the deck for a slider.
The silver screw is your non full depth adjustment, for doing dado type cuts, etc.. and has the flip out tang for flipping back to full depth.
marineman
Wild Rose, WI
He got it right, I have the same saw in green from Menards, you're going to like it.
Josey
Southern Illinois
Be careful with the guard arm! I got 4 cuts out of mine and it broke. I returned it and ended up getting the Admiral. No problems so far.
90zcar
Thanks guys. Yes I love this saw so far. I have been using the **** out of it and for the 88 bucks it spent on this I love it!
noslin
thats a good price, what coupon did you use with it? I just looked on an HFT app and they have the non-sliding one for 79 but would like to get the sliding one like you have.
Dean
tomwil
Dean
https://www.hfqpdb.com/coupons/55_ITEM_10__SLIDING_COMPOUND_MITER_SAW_1534575601.1905.png
jonshonda
Wisconsin
I really want to try a cheap saw like that, but just cannot bring myself to not fantasize about the bosch glide saw. Hmmmm.....I could buy 7-8 of the HF saws for one Bosch.
