Harbor Freight 12” disc sander YES or NO?
Shiftless
East Bay SFO
I know that the HF belt sander/6 inch disc sander gets rated as a major fail but what about the stand alone 12” disc sander?
My old Craftsman combo belt/disc sander finally died and I’ve been without a bench sander for a year or so. I’m thinking of buying this one for very occasional use.
My intended use is mostly surfacing small bits of metal like vise jaws so they fit better or to remove minor gouges.
This HF model seems to have a decent table so a user can square up his work.
I realize that small bits can’t be safely hand held so I’d use a small machinist vise to hold them securely.
Do any of you guys have one of these or similar ones like Delta or ??? If so, what do you think of it?
Thanks for your honest opinion.
tarbellb
Oregon
Its a good sander for the money.
12" disc is a excellent addition to the shop. A belt is nice too, but skip the combo they sell.
If you are really considering a belt sander, look into converting a bench grinder with the MultiTool attachement - https://www.amazon.com/dp/B00BNBAQ90/?tag=atomicindus08-20
or
Grizzly sells a pretty nice combo. After that it only gets much more expensive.
dwcon1431
Regardless of what size you choose, if you get the extended warranty and have any problems, HF will replace or refund. For a limited use machine, I don't see how you can go wrong.
Sent from my SM-A102U using Tapatalk
BD1
north side
Have you checked facebook marketplace or Craiglist for a older 12" disc like Delta ?
There have been quite a few stand alone ones for $75 to $100.
Have you considered just making one?
FlaGman
Western North Carolina
I picked one up for about $120 on sale a few years ago, I like it a lot. I was originally going to occasionally use it with a hitch receiver on my bench, but it is so heavy I just permanently attached it instead.
Prospecter
Maine
I like mine. Issues usually are related to excessive vibration due to balance. The solution is to unbox and try it out as soon as you get it home so you can return it if necessary. Mine was fine right out of the box.
Gus_Mahn
Chicagoland
I have the 12" HF disc sander. I think it works fine for what it is and costs. I don't think it has the nuts that a higher quality sander would, but it's fine as long as you pay attention and don't bog it down.
DerekV
Central TX
I’ve had an “Ironton” (Northern Tool brand) version for about 5-6 years now and it’s awesome. A family member has the HF version and he loves his. If mine died today, I’d get another one in whatever brand is easiest to get. These 12” sanders are a great value, which is unlike most inexpensive stationary sanders/grinders in my experience.
ItsNemo
Canada
I have the King tools version of it...didn't come balanced well, took the wheel off and they just drill holes in the back to balance it, so I added a few more where it needed it until I got it nice and smooth.
dogdog
that 12" disc sander is good, the motor is 1.5 HP or something ... I think it went down to $139 sometime back. not sure. There are few youtube videos that have good review of it as well... I think there is a thread here or at least a few post about this particular one as well some time back 1 or 2 years back...
22george
SW Ohio
I've had one for 30 years. Don't use it that often, but have had no issues with it. It has done what l needed it to do.
david3921
Wyoming, Michigan
I have one and like it. As noted, it's pretty heavy. The vacuum port is full size so my 16 gallon Craftsman hooks right up. Most of these come with the right side covered, this one doesn't. This doesn't mean that you can use that side, though. Always use the left side for safety.
