Harbor Freight 20 Ton Hydraulic Press Upgrades
whateg01
doo dah, kansas, usa
The bed on my press is probably twice or more the weight of that one. I've been thinking of adding a winch for your for years but haven't yet. Good idea!
RacerX
Caldwell, Tx
Very nice additions of the winch, roller guides, release knob, press brake.
Could you provide the source for your additions?
Worthwhile additions and would like to mimic your ideas!
C
c7z06
Edgewater, MD
Winch was from Amazon: Atlas part no. B085RTXMZX
I fabricated the plates for the roller guides. Rollers are 1" cam followers from McMaster-Carr
I made the release knob from an old timing pulley
Finger brake was from Swag OffRoad (https://www.swagoffroad.com)
GeoBruin
Very cool. I love the lift. My press is a bit different and there's a protrusion on top of the top crossmember that might cause some issues but I think I could work around it.
I recently got the air jack and I ordered a foot pedal for it but I'm now questioning whether to use it or just mount the hand trigger nicely.
Not to get too far off topic but how do you like the SWAG finger break kit? I assume you got the weld it yourself version?
C
c7z06
Edgewater, MD
I like the Swag finger brake, although I don't use the fingers that much - just the entire surface. It's a little tedious getting it in and out to use it as a regular press. Most of the time I just leave it in and use my arbor press. I got the already welded version, as it was worth the extra $150 to me to not have to fool with it.
C
c7z06
Edgewater, MD
A suggestion: If you do everything i did, there's a lot of hole drilling. I bought a Rotabroach set, which made it a whole lot easier. About $85.00 with free shipping from Amazon - Blair part no. 11090. Probably even cheaper if you look around.
PBCampbell
WV
Well that is clever. I doubt I would have ever thought do that. Excellant job all around.
vwpieces
Hills, PA
I like those guide rollers.
I have the old Orange 20T one, might have had it 20yrs now.
Very first upgrade was polishing the jack ram because it was peeling rubber boogers from the seal. Machining grooves were pretty rough, definitely not ground. That jack still lives today.
Next was a set of casters and I mounted the 3/4dr Pittsburgh MM socket set case to the top of the press. I use that socket set more on the press than I ever did on nuts etc. Casters were taken from the small $8 movers dolly. Can't buy 4 casters for $8......
Last upgrade was the air/hydraulic. Searched for a deal and finally got one for under $70. That jack just quit on me, on the air side. I took it apart and found a sliver of metal stuck in the ball check on the bottom of the air pump. Hand pump still worked so I was able to get through the job at the time. Fixed again and I also extended the hose leader to the air valve.
Crappy press but it has survived and done what I have asked so far in the past 20yrs.
Farmall450
Marengo, Illinois
I do want the SWAG brake (or to make one). However I found a steal on a NIB brake that you toss your own 20t bottle jack into, so ig I'm running with that.
C
c7z06
Edgewater, MD
I'm in the process of dealing with this issue myself. This is the approach I'm taking.
If you have a winch installed to raise and lower the deck, the problem is easily fixed. Just lower the existing deck (table) way down, and fabricate a second deck from a length of channel. It can be quickly inserted above the brake in the frame and used for pressing. The second deck can be made as sturdy as necessary for the pressing you intend to do. Use a wooden block to raise the pressing surface as needed. See drawing below:
GeoBruin
Now we're talking. The swag finger break is on my short list of projects and so is a copy of your lift build.
C
c7z06
Edgewater, MD
For any who may want to do something like this to their Harbor Freight press, here are some specifics about the parts used:
The brackets to be welded to the ends of the channel were CNC plasma-cut from 1/4" mild steel. The diagram below shows the dimensions. The 22 1/4" long channel is 4" wide, with 1.72" legs, and .321" web thickness. This is commonly referred to as 4 x 7.25 channel since it weighs 7.25 lbs. per foot. The two pins are 13/16" diameter, and 6" long. Shaft collars on one end will keep them from inadvertently slipping through the hole.
While heavier 4 x 13.8 channel is available, I didn't think I needed it or the extra weight for my purposes, as most of the time a 22" length of 6 x 6 will be on top of it.
alfadan
Augusta, ks
I made an adapter and put a 3/8 electric drill on my boat winch. Im kinda meh about it though; its a little too fast, have to be carefull.
bb29510
im sorry, Im not putting wheel on a press, I got a broken arm for a press dipping over on me, wheel would just make it easlier
C
c7z06
Edgewater, MD
Here the 2nd table is installed in the press above the lowered Swag brake. Two of the height adjustment frame hole levels are still available above the brake. The 6x6 block of wood acts as a spacer, and adds stiffness if needed. The 18 lb. table can be removed and the brake raised for use in about 5 minutes time. The brake bolts to the frame in its raised position, which takes about 3 out of the 5 minutes.
alfadan
Augusta, ks
Josh at Topper Machine has a video on facing the plates on a HF press on a lathe. They were pretty crummy but cleaned up well.
imagineer
This has been done for a while, but I was snapping pics today...
I added a strap winch to the top for raising and lowering the anvil beam. It was tricky getting the strap to spool from the middle and stay equal. I used a piece of PVC tube, slit, to snap over the arbor of the winch and clamp the strap. I ended up laying a bead of weld on the winch arbor to prevent the strap and PVC clamp from rotating on the arbor.
The ends of the straps have small d-rings bolted that hook onto eyebolts that are fastened to the anvil beam.
The winch I used ratchets in one direction only, so to lower the anvil beam, I've got to flip the ratchet off and "free-wheel" the winch. With my free hand, I have to insert the anvil beam pins.
The other upgrade was to add V-notch rollers to guide the ram.
Without guides, the ram beam has about 1/4" play in all directions and also can tilt out of horizontal by about 5 degrees. This excess play and tilt gave me trouble when using this press to rebuild a set of steering knuckles.
The brackets for the v-notch rollers are each made from 3 pieces of steel angle and a 5/16" steel base plate. I thought about just adding some UHMW pads to limit the excess play, but that would not have solved the undesired tilt problem. This system took some time to get everything adjusted, but now there's no noticeable play or tilt on the ram.
Not photographed, but the press is also on a rolling base that has storage and the anvil plates were drilled for roll pins to help them stay aligned on the anvil beam.
Next on the to-do list for this press is to make a finger brake (ala SWAG offroad).
