Wangstang
So many have come to trust the 20-ton Harbor Freight press despite it's enduring reputation for a leaking jack. The outstanding price and solid construction at the $150 price point with various coupons have made it a useful tool for DIY's of all types.
This would be the original, well known, 20-ton Press, item 32879 :
Central Hydraulics - item#32879
http://www.harborfreight.com/20-ton-shop-press-32879.html
It looks like Harbor Freight used an alternate part number for a 12" taller version of that's also got about 6" of extra width on the work surface same design, item 97022 :
Central Hydraulics - item#97022
http://www.harborfreight.com/20-ton-h-frame-shop-press-97022.html
http://manuals.harborfreight.com/manuals/97000-97999/97022.PDF
Harbor Freight is now phasing in a new model that doesn't come up when you search for 20-ton presses on the website but will show up if you search by the new item number 60603 :
Central Hydraulics - item#60603
http://www.harborfreight.com/20-ton-shop-press-60603.html
I found this new press on the website about two weeks ago when I ran the item numbers on the coupon from Car Craft magazine and I've been trying to get a bit more info on it.
It looks like the new bolt together 20 ton was spec'ed to the larger size of the 97022 welded frame model.
At first glance, the 60603 appears to be a mix of the Greg Smith Equipment 20 ton and 30 ton presses:
http://www.gregsmithequipment.com/20-Ton-Hydraulic-Shop-Press_2
http://www.gregsmithequipment.com/30-Ton-Hydraulic-Shop-Press
Also kind of favors the grizzly 12 and 30 ton press:
http://grizzly.com/products/30-Ton-Shop-Press/H6228
http://www.grizzly.com/products/12-Ton-Hydraulic-Press-Floor-Model/H2871
The most notable difference is that the new 20 ton uses a bolt together frame vs a welded frame. The work surface appears to have extra bands on the outside of the frame to prevent them from dropping out of alignment and the springs have been moved outward as well.
I've heard stories here of the welded frame cracking and of the frames not being square from time to time so I'm not sure that a bolt together frame is so bad.
The first report I've heard of the 60603 in the wild was from yesterday, over at Slick Deals:
Obviously the above poster didn't know there was a change coming and jumped to the conclusion that the new version is bad due to the reputation of the 12 ton as he didn't make it out of the store with the new 20 ton.
I'm in the market for a new press now, something that will probably only be used a few times a month at best, more likely only a few times a year.
Should I rush out and get a welded frame model before they are gone or should I get the new bolt together version?
Thanks
Wes
Name Shop Press, 20 Ton
SKU 32879
Brand Central Hydraulics
Capacity 20 tons
Material Steel
Maximum width between channels 16-3/8"
Maximum working distance (in.) 32 in.
Minimum working distance (in.) 0 in.
Product Depth 26 in.
Product Height 5 ft.
Product Width 26-1/2 in.
Accessories Included Arbor Plates
Warranty 90 Day
SKU 97022
Capacity 20 tons
Material Steel
Product Depth 27 in.
Product Height 6 ft.
Product Weight 100 lbs.
Product Width 28 in.
Travel length (in.) 4-7/8 in.
Width between channels (in.) 22-1/4 in.
Warranty 90 Day
Name 20 Ton Shop Press
SKU 60603
Brand Central Machinery
Capacity 20 tons
Material Steel
Product Depth 27-5/8 in.
Product Height 6-1/12 ft.
Product Width 27-7/8 in.
Travel length (in.) 5-1/2 in.
Accessories Included Arbor plates
Warranty 90 Day
Well got the 20 ton press, when the guy came around with the cart it had just 2 boxes, 1 long maybe 12"x12", other had the jack,I bought one 6 months ago It had the large flat box where the frame is in, and I never used it and returned it for the motorcycle lift, well the new ones are NOT WELDED there BOLTED like the POS 12 ton!!
They said this is what were getting from now on, i was pissed!!, so i asked for the display model, and took that home, no wobbly bolted frame for me!
The new style press is grey painted, not orange, it also had a part # something like 80XXX
Thanks
Wes
