Harbor Freight 60 Gallon Air Compressor 93274
GRivera
20 mins south of Baltimore
I’ve had the 60 gallon HF 93274 Compressor for about a year but only just started it today. Per instructions, I did break-in by running it for 30min with all valves open/no load. This was done with the HF brand oil. What I can’t find is when to drain and refill with new oil. Anyone out there can advise? For instance, should I just use it for ** number of hours on the break in oil and then drain/fill?
Compressor:
https://go.harborfreight.com/sku/93274/
Manual:
https://manuals.harborfreight.com/manuals/93000-93999/93274.pdf
As far as the oil after break in I plan to use a name brand synthetic.
jdrais
Eveleth MN
The manual says change the compressor oil after the first
hour of use to remove any debris.
Or are you asking the maintenances schedule (on page 14 of the manual) says
Every 6 months or 100 Operation Hours:
Replace Pump oil.
