Harbor Freight AC Gauge Question
47newcastle
Hello! I just bought a AC manifold gauge set from HF. When I opened it i noticed that the low side gauge needle was at 1psi not 0. I also noticed that there are caps on the gauge to remove and insert a screwdriver into. I'm guessing this is to adjust the gauge? Is it as easy as turning the screw until it is at 0? I know its just 1 psi but it bugs me. I just wanted to run this buy you guys before I mess up my gauges. The instructions did not say anything about it.
AmickRacing
Rapid City, SD
Yup, that's what the lil screw is for! All refrigeration gauges will have those zero-adjust screws.
Now, if you want to be reeeeaaaaallly **** about it, technically the gauge should be calibrated around the middle of the working pressure range. Back when I had more time to be ****, I'd bring in a jug of R-22 and leave it in the house for a day or 2. Take the temp of the jug, gauge up to it, use the PT chart, and adjust the gauge so that read accurately, which typically made it a bit off on the low end, but it wasn't much at all. Since I work on fairly large tonnage HVAC units, honestly I don't worry about precision quite as much. Seems like small coolers and freezers are where the precision is needed.
47newcastle
Thanks! I should be fine then since it was only off by 1. I'm just using it to evacuate and fill ac systems in vehicles.
crewchief888
NW indiana
one of my co-workers has a HF A/C guage set...
quite possibly the biggest pile of **** i've ever attempted to use.
BOTH couplers leaked first time out of the box...
i finally got them to seal to the QD by clamping them onto the hose..
he returned them, at least the 2nd set only had one coupler that wouldnt seal.
:beer:
Tim C
I don't know about the HF gauges, but I've got a cheap set from advance auto for home use. It had the problems with the couplers leaking or not locking on. Mine would unscrew from the hoses so I bought the couplers from the Mac truck they were $45 each and after locking it on you screw it down to engage. The gauges work great now.
