harbor freight auto fuses... Wow!
autoclassicnut
Montana
Was having trouble with my after market auto electric windows acting up.... Here's what I found in the fuse box... the fuse holder was melting and as you can see the fuse didn't blow! Needless to say all of the fuses are replaced with " real ones " now.
Norcal
Buying safety devices made in China at Harbor Freight....:mad: Sorry for the rant but one has to be really careful when buying stuff there.
Mike_C
I never even considered buying HF fuses... Not something to go cheap on, good fuses from your local parts stores are not that expensive.
I bought a assortment pack of hose clamps from HF, figured it would be nice to have a handful of sizes on hand. I went to use one, and it stripped out very quickly. The entire box found its way into the trash.
With that said, I still buy a lot of stuff from HF. But hardware is something I pass on, other then their thread in rivits.
Since we are talking about fuses, I have a good picture. A couple years ago I stopped to buy some parts for my 4runner. Jumped back in the 4runner and it wouldn't start. I started looking over everything, and finally checked the fuses. The ignition fuse on the kick panel had melted! I was very concerned as to what had caused this of course. After doing some research on the issue, I found it was do to a loose connection. The blade holder was loose, so I simply pinched it back together.
Here is the fuse I pulled out.
sstruckguy
Paducah, KY
Not only was the self generated recall done, General Motors issued a TSB that warned of their use. If I remember the wording correctly, "the product fails to blow, puts undue stress on the circuit, which results in a non-warranty situation."
