Harbor Freight Coupon Thread
kd4gij
St. Petersburg, Fl
I was in HF today and noticed that some of there socket and ratchets are now made in tiwan. Are thay stepping up there game in hand tools now?
alpaca
pretty sure most if not all pittsburgh pro hand tools are made in taiwan its the regular pittsburg stuff thats china
BK13
PDX, OR
I can't speak to the sockets, but the three new lines of ratchets seem like well executed tools to me... the new composite, the flex low profile and the non-flex low profile. Good enough for my uses, anyway.
77Ford
Looking for motorcycle lift coupon for my brother. Is 20% off the best I can do?
Thanks ahead of time
jeopardy98
Prince George, VA
Yes it does because you see there is no option for using the 20% coupon on that item. All other items say use 20% coupon if price is less than x amount. Ergo 20% no good.
bdresch
Any coupons on the 18x72 solid drawer liner? #65565. I need 4 rolls and can only use the 20% on one.
mdbeck1
Norman, OK
It still doesn't answer the question in everybody's mind....
"Can I use the 20% off coupon on the HF 44 toolbox?".
Says on the coupon cannot be used on tool storage or carts...so probably not....
Unless you take it to a store and get lucky like some have...
The answer to that is a resounding "no".
That post was a poor attempt at a joke. I think the most popular post here is asking if those 20% off coupons will work with tool storage. If the people would just read the coupon.....
The database won't fix that question. ....but it will fix the questions about the current active coupons. Good move.
leftyz
Upstate, NY
Ah a joke, it went right over my head :-D
We added a flag for every item if the percent coupon wont work for it, we don't show the "use 20% coupon if current price < $**.**"
markmdz
Anyone know if the long reach, low profile floor jack has been in a coupon?
Sure would be nice to get one for $80 or so ...
IMO, this is one of those items HF sells that I'd say is well worth even the full price. I have two of these and cannot believe how much better they are than the old clunkers I grew up using. ...plus it's the only jack I've ever owned that fits under my car without having to drive up on blocks just to fit the jack under it.
Caparris
Greensboro, NC
The mailer I just got over the weekend shows a price of 77.44 for this, well worth the price.
I have a bmw 318iS with a very low hanging oil pan and it fits under it to lift the front end via the crossmember.
I have that one too, or one very similiar at least. Works great. I got the "crossbeam" that they sell also and it works well. On my Corvette I use a separate jack to jack one front side up a bit, then put a jack w/crossbeam under from the front and pick the whole front up at once. On cars with more ground clearance you could just pick the front up in one step, there's just not enough room on this particular car though
jeopardy98
Prince George, VA
Could you snap a picture of that mailer? I'm not seeing that price on the coupon webpage.
On a side note, do you all suggest these over the aluminum ones?
markmdz
100%. I have yet to see an aluminum jack other than super high end ones with the low profile, long reach and lift height of this jack. The rapid-pump is just icing on the cake.
I'd love a pic of that mailer too. At that price, I'll buy a third one to have in the garage as a just incase.
jeopardy98
Prince George, VA
I see now. Only offered long reach in a 2 ton. The 3 ton low profile is $30 cheaper. Is the 1 ton less capacity and higher price tag really worth having the long reach?
cagullett1
North Texas
Go look at the 2 in person. The 2 ton is MUCH larger, has additional features such as the release knob on top handle, and a foot pedal to get the jacket up to the vehicle faster. I know a few people with it and have had no issues front ends on 3/4 ton pickups. The only reason why I haven't bought it is because I got a screaming deal on another 3T and am waiting for it to die before I replace it.
EDixon
Aiken, SC
I have the 2 ton low profile aluminum, and the 3 ton low profile steel jack. The steel has a lower saddle, higher lift, and longer reach than the aluminum, and the 2 ton steel has an even longer reach. The 3 ton can barely get to the front cross member of my lowered 240sx, but it works. FWIW, my 2 ton al has no issue picking up the front or rear of my 1500 Avalanche.
