Harbor Freight Coupon Thread
LS6
NY
So since the 25% coupon for 4/16/17 has so many restrictions, what can we use it on?
hostilityy
Harbor freight doesn't offer their 20% off entire purchase coupon anymore. I want to buy all the different sizes flex head professional ratchets; are they usually cheaper than the everyday price during the parking lot sale?
Locker537
Massachusetts
I've never seen them in the parking lot sale. Use a 20% coupon on each one. Only inconvenience is you will be making purchases on different days.
falconero
Recent mailer
79683852
Sent from my Pixel XL using Tapatalk
P0larbear
Pretty sure it's all returns
Yeah they are labeled AS-IS merchandise. Basically anything that harbor freight sends back. They refurb and resell. Some of it isn't bad though. Just gotta sort through it all.
leftyz
Upstate, NY
Lots of price changes last night...
5/25/17: HEAVY DUTY FOLDING STEEL CARGO CARRIER Item Lot No. 62660 - $89.99 DOWN from $99.99
5/25/17: 2-7/8" Magnetic Bit Holder Item Lot No. 36555/62692 - $1.99 UP from $0.99
5/25/17: 4" RATCHETING BAR CLAMP/SPREADER Item Lot No. 68974 - $1.99 UP from $1.69
5/25/17: Clamp Item Lot No. 68974 - $1.99 UP from $1.69
5/25/17: 9 mil Nitrile Powder-Free Gloves 50 Pc Item Lot No. 68510/68511/68512 - $12.99 UP from $11.99
5/25/17: RATCHETING CRIMPING TOOL Item Lot No. 97420 - $12.99 DOWN from $14.99
5/25/17: LEAF RAKE WITH WOODEN HANDLE Item Lot No. 67535 - $8.99 DOWN from $9.99
5/25/17: 12 PIECE SNAP CLIP FASTENER SET Item Lot No. 67563 - $3.79 DOWN from $3.99
5/25/17: 10" sliding compound miter saw Item Lot No. 61971/61972/98199 - $114.99 UP from $109.99
5/25/17: 29 ft. 4" X 49 FT. ALL PURPOSE/WEATHER RESISTANT TARP Item Lot No. 69194/60473/2142 - $89.99 DOWN from $94.99
5/25/17: FOUR-WAY TRAILER WIRING CONNECTION KIT Item Lot No. 62990/96658 - $8.99 DOWN from $9.99
5/25/17: 10 FT X 20 FT CAR CANOPY Item Lot No. 60728/69034/63054/62858/62857 - $129.99 UP from $119.99
5/25/17: 42" LONG REACH AIR SCRAPER Item Lot No. 69236/62687/37073 - $119.99 UP from $109.99
5/25/17: 7" wet cutting tile saw Item Lot No. 40315 - $67.99 UP from $59.99
5/25/17: 3/8" X 30 FT. AIR HOSE REEL Item Lot No. 40131/69232 - $34.99 DOWN from $44.99
5/25/17: 33 PIECE COMFORT GRIP SCREWDRIVER SET Item Lot No. 61255 - $10.99 DOWN from $11.99
5/25/17: 150 LB. CAPACITY FOLDABLE HAND TRUCK Item Lot No. 61867 - $25.99 DOWN from $27.99
5/25/17: 7" PORTABLE WET CUT TILE SAW Item Lot No. 40315/69231 - $67.99 UP from $59.99
5/25/17: 1" X 14 FT. RATCHETING TIE DOWN Item Lot No. 62762/61295 - $1.99 UP from $0.99
5/25/17: CO2/ARGON REGULATOR GAUGE Item Lot No. 94841 - $35.99 DOWN from $36.99
5/25/17: 1 GALLON CITRUS HAND CLEANER WITH HAND PUMP Item Lot No. 43222 - $10.99 DOWN from $12.99
5/25/17: 10 PIECE 3/8" DRIVE COLOR CODED SOCKET SETS Item Lot No. 61339/93262/61292/93260 - $9.99 DOWN from $10.99
5/25/17: ALUMINUM CARGO CARRIER Item Lot No. 92655/69688/60771 - $79.99 UP from $74.99
5/25/17: OVER-THE-WHEEL TIE DOWN BONNET Item Lot No. 97230 - $25.99 DOWN from $27.99
5/25/17: 4" HEAVY DUTY ANGLE GRINDER Item Lot No. 60373/91222 - $19.99 DOWN from $21.99
5/25/17: 11 PIECE FULLY POLISHED LONG HANDLE COMBINATION WRENCH SETS Item Lot No. 44718/60538/47067/60548 - $24.99 UP from $22.99
5/25/17: PISTOL GRIP GREASE GUN Item Lot No. 61575/66664 - $16.99 DOWN from $17.99
5/25/17: 32 OZ. HEAVY DUTY MULTI-PURPOSE PAINT SPRAY GUN Item Lot No. 69704/97855 - $23.99 DOWN from $24.99
5/25/17: 15 PIECE, 6", 9" BI-METAL RECIPROCATING SAW BLADES Item Lot No. 62126/68043/68943 - $14.99 DOWN from $15.99
5/25/17: 5 PIECE, 9" 4-5 TPI RECIPROCATING SAW PRUNING BLADES Item Lot No. 62219/68040/68946 - $8.99 UP from $7.99
5/25/17: 1-1/8" BI-METAL MULTI-TOOL PLUNGE BLADE Item Lot No. 61812/68912 - $9.49 DOWN from $9.99
5/25/17: 28 LED WORK LIGHT Item Lot No. 66274 - $17.99 DOWN from $19.99
5/25/17: 20 PIECE 3/8" DRIVE HIGH VISIBILITY SOCKET SETS Item Lot No. 41723/67999 - $21.99 DOWN from $22.99
5/25/17: 12" TOOL TOTE Item Lot No. 61471/62350/62485 - $13.99 UP from $11.99
5/25/17: 19" TOOL TOTE Item Lot No. 61470/62372 - $19.99 DOWN from $21.99
5/25/17: 6 PIECE WATERING CONE SET Item Lot No. 93182 - $2.99 DOWN from $4.99
5/25/17: HEAVY DUTY BENCH GRINDER PEDESTAL Item Lot No. 68321 - $52.99 DOWN from $54.99
5/25/17: 3/4" HEAVY DUTY AIR IMPACT WRENCH Item Lot No. 60808/66984 - $94.99 UP from $89.99
5/25/17: 4 FT. x 12 FT. POLY COATED DROP CLOTH Item Lot No. 93713 - $14.99 DOWN from $15.99
5/25/17: 48" HEAVY DUTY SCRAPER Item Lot No. 60572 - $12.99 DOWN from $13.99
5/25/17: 20 TON AIR/HYDRAULIC BOTTLE JACK Item Lot No. 69593/95553 - $119.99 UP from $99.99
5/25/17: 1600 WATT HEAVY DUTY DUAL TEMPERATURE HEAT GUN (1000/1100) Item Lot No. 66098/69342 - $37.99 DOWN from $39.99
5/25/17: MOTORCYCLE STAND/WHEEL CHOCK Item Lot No. 97841/61670 - $57.99 DOWN from $59.99
5/25/17: MOTORCYCLE WHEEL CHOCK Item Lot No. 69026/60392 - $37.99 DOWN from $39.99
5/25/17: 500 WATT PORTABLE HALOGEN SHOP LIGHT Item Lot No. 66433/60557/61576 - $13.99 UP from $11.99
5/25/17: 9 FT. x 12 FT. CANVAS DROP CLOTH Item Lot No. 69308/38109 - $16.99 UP from $15.49
5/25/17: TIRE CHANGERS Item Lot No. 62317/69686 - $42.99 DOWN from $44.99
5/25/17: AIR HOSE REEL WITH 3/8" x 30 FT. HOSE Item Lot No. 69232/40131 - $34.99 DOWN from $44.99
5/25/17: 18" PVC BRISTLE BROOM Item Lot No. 97402 - $9.49 DOWN from $9.99
5/25/17: 8 PIECE MAGNETIC SCREWDRIVER SET Item Lot No. 7386 - $6.99 DOWN from $7.99
5/25/17: 42" LONG REACH AIR SCRAPER Item Lot No. 69236/37073 - $119.99 UP from $109.99
5/25/17: 5" HIGH SPEED AIR SANDER Item Lot No. 68739 - $17.99 DOWN from $19.99
5/25/17: 13 GALLON INDUSTRIAL PORTABLE DUST COLLECTOR Item Lot No. 61808/31810 - $144.99 DOWN from $149.99
5/25/17: 8 PIECE BOLSTERED SCREWDRIVER SET Item Lot No. 94899 - $11.99 DOWN from $12.99
5/25/17: 4 OZ. ADJUSTABLE DETAIL SPRAY GUN Item Lot No. 61933/92126 - $13.99 DOWN from $14.99
5/25/17: 3 PIECE PRY BAR SET Item Lot No. 60674/68339 - $6.99 DOWN from $7.99
5/25/17: 22 PIECE SCREWDRIVER SET Item Lot No. 69420/95114 - $10.99 DOWN from $11.99
5/25/17: POWDER-FREE NITRILE GLOVES PACK OF 50 Item Lot No. 68510/61742/68511/61744/68512/61743 - $12.99 UP from $11.99
5/25/17: 7" WET CUTTING TILE SAW Item Lot No. 40315/69231 - $67.99 UP from $59.99
5/25/17: PORTABLE FISH FINDER Item Lot No. 62675/94511 - $39.99 DOWN from $47.99
5/25/17: BENCHTOP ROUTER TABLE WITH 1-3/4 HP ROUTER Item Lot No. 95380 - $99.99 DOWN from $109.99
5/25/17: 4-1/2" HEAVY DUTY ANGLE GRINDER Item Lot No. 91223/60372 - $19.99 DOWN from $21.99
5/25/17: 14" OSCILLATING SPINDLE SANDER Item Lot No. 69257/95088/62146 - $139.99 DOWN from $144.99
5/25/17: 10", 13 AMP INDUSTRIAL BENCH TABLE SAW Item Lot No. 63117/63118/68827 - $139.99 UP from $129.99
5/25/17: STEEL CARGO CARRIER Item Lot No. 66983/69623 - $54.99 DOWN from $64.99
5/25/17: LED TRAILER LIGHT KIT Item Lot No. 62492/62487/62488 - $37.99 UP from $29.99
5/25/17: HEAVY DUTY HAND TRUCK Item Lot No. 62775 - $39.99 UP from $37.99
5/25/17: 500 LB. CAPACITY ALUMINUM CARGO CARRIER Item Lot No. 92655/69688/60771 - $79.99 UP from $74.99
5/25/17: 1500 LB. CAPACITY MOTORCYCLE LIFT Item Lot No. 2792/69995/60536/61632 - $89.99 UP from $84.99
5/25/17: 1195 LB. CAPACITY 4 FT. x 8 FT. HEAVY DUTY FOLDABLE UTILITY TRAILER Item Lot No. 62170/62648/62666/90154 - $299.99 UP from $279.99
5/25/17: 45 WATT SOLAR PANEL KIT Item Lot No. 68751/62443 - $149.99 UP from $139.99
5/25/17: 72" x 80" MOVER'S BLANKET Item Lot No. 66537/69505/62418 - $8.99 UP from $7.99
5/25/17: 18 GAUGE 2-IN-1 NAILER/STAPLER Item Lot No. 68019/61661 - $22.99 UP from $19.99
5/25/17: 2 HP, 8 GALLON 125 PSI PORTABLE AIR COMPRESSOR Item Lot No. 67501/68740/69667 - $124.99 UP from $115.99
5/25/17: 10" SLIDING COMPOUND MITER SAW Item Lot No. 98199/61307/61971/61972 - $114.99 UP from $109.99
5/25/17: RAPID PUMP 4 TON HEAVY DUTY STEEL FLOOR JACK Item Lot No. 68056/60706/62319 - $129.99 UP from $124.99
5/25/17: 170 AMP MIG/FLUX WIRE FEED WELDER Item Lot No. 68885/61888 - $179.99 UP from $174.99
JonnyC
Green Bay, WI
Hey leftyz,
Do you crawl the site to record prices? I assume that's how you come up with the price change list. I've always wanted a camelcamelcamel for HF. Have you thought about adding the ability to look up a product and just show a simple price history?
Thanks!
