So Im not sure what my buddy is doing wrong, but he has had 2 different HF floorjacks fail by twisting the frame. Both of these were used on 3/4 ton work trucks which were loaded with about 1000lbs in the bed. Both of them failed with the jacks supporting the truck on the pumpkin on the rear and then the actual frame of the jack twisting. In both instances he claims the jacks were supporting the truck fine then he heard an awful noise and the truck almost falls and winds up with a twsited jack. All he is doing is rotating his tires and the front is supported on stands.
Jacks in question are 3 tons, one is the aluminum one part # 68052 and the other was the steel low pro part # 61253/#61282.
For the life of me I cant figure out how he is doing this unless the jack is slipping but this was on 2 different trucks and one especially was on a totally flat and level surface pretty much and the other on a very very slight incline. Both jacked up on the pumpkin, truck 1 is a 3/4 ton chevy full size express van and truck 2 is a 2012 chevy 2500hd crewcab 8ft bed.
Are these jacks just junk or is he unlucky or something? Are the jacks apparently although rated for 3 tons closer to 1 ton or something?
