Harbor Freight Gear pullers any good ?
SEV22XS
So I need to pull a bearing off a crank for my air compressor rebuild are the harbor freight gear pullers any good ? I know there cheap but I won't use them everyday.
defektes
Arizona
As long as you do not put high torque on it, it should be fine. When you really start cranking on them they fail. My company orders them all the time, and being used and abused they do not last. For a project here and there should be ok.
Craptain
Tampa Bay FL
I get them on free loan from Advance autoparts. You pay up front and then get a full refund when you return it.
bwringer
Indianapolis
Look at renting one from Autozone or Oreillys first.
Uh, it'll be the exact same Chinesium, except it'll come pre-abused and pre-busted. :headscrat
That said, the HF unit will most likely work fine for what you want to do. It's a very simple tool.
The expensive stuff is great when you have very limited access (so things like sharp edges and precise geometry are important) or are dealing with extreme forces.
