bczygan
Anyone have and use one?
What uses?
Any good?
Any problems?
Bill
What uses?
Any good?
Any problems?
Bill
Actually that is a pipe kinker not bender....
It has it's uses but they are few and far between. With a lot of modification and finesse it will actually make some decent bends. However, the level of effort is not worth it for the return.
This is HF's tubing bender. Never have used it.
http://www.harborfreight.com/tubing-roller-99736.html
Actually its a tubing roller better for making hoops or big sweeping curves. My idiot brother bought one to try and buiild a roll cage with. He quickly found out what type of bending it does and it takes a ton of arm strength to get a 1 1/2" .095" wall tube to a 90 degree bend.
Well, that answers that!
Was one on CL for $20.
Probably not worth it.
Bill
yea it's a pipe bender.
i have one, it works for bending pipe, but it crushes and kinks tubing.
mine works a lot smoother after i cleaned all the casting marks off the shoe, lubed the roller pins, and use some lube on the shoe when bending.
i've used mine quite a few times.....
