Harbor Freight Impact wrench comparison updated video
gi bro
Bristol, CT
Hi All,
Here is an updated video on my harbor freight impact wrench comparison video. I think the update have given more justice to the video and perception.
Please leave your comments as I would like your take.
Check out my in depth review, comparison and tutorial on the Harbor Freight Central Pneumatic and Chicago Electric Impact guns.
Harbor Freight 1/2in Electric Impact Wrench Vs. Air Impact Wrench Review and Test 68099 & 94802
<iframe width="560" height="315" src="https://www.youtube.com/embed/rjP6t8Nu9Bw" frameborder="0" allowfullscreen></iframe>
thebeekeeper1
Illinois
I'm impressed. :)
I have the Milwaukee electric one and wouldn't DARE put lug nuts on with it, as it will zip them to 300+ ft. lbs. in an instant. Off is great, but on is a PITA.
G
gi bro
Bristol, CT
I learned not to use impacts on lug nuts, but the electric seems to be ok for heavy duty trucks. I make sure to use my torque wrench to set them to 100ftlbs.
Zexx
GA
Check your regulator on your "junk" compressor. Find out the recommended PSI for the impact. Adjust the regulator to the recommended PSI while the impact is running. To me it sounded like your regulator was only set around the 30PSI range, and the regulator on your neighbors was running a much Higher PSI.
If your compressor is working as designed it can handle that impact just fine, the tank will be at 125PSI until it drops below a certain amount, then the compressor will kick on to build it back up.
XxToolAholicxX
SF **** Bay Northern California
Great video and review keep them coming.... Thanks
I am a ToolAholic, Sometimes I regret it, Especially when the Toolman wont give me no credit
G
gi bro
Bristol, CT
I doubled checked the regulator and made sure it was at 90psi. The wrench calls for 7 scfms and the compressor only goes to 5.3cfm. I might replace the regulator but I think the unit is just very limited in its use. Thanks for your advice.
