Harbor Freight Inner Tie Rod Tool.
Kenskip1
Missouri
Ok, Merry Christmas to all.. So last night while scanning HF site I stumbled upon the inner tie rod removal tool on clearance for $16.95.Well it just so happens that the wife's 2003 Windstar needs a set of these. Has anyone used this tool and what was the outcome? It is supplied with 7 slotted adapters. I am hoping that one of these will fit her Windstar. And yes I brought the last one in stock and it is now resting within the confines of my tool assortment. Thanks, Ken
mrvm
PA
As a non-pro auto repair specialist the HF Maddox inner tie rod tool set worked as designed for my Honda Pilot. Not sure I would have got the inner tie rod off x2 as easily.
Was that a returned item or damaged/missing parts at the clearance section?
K
Kenskip1
Missouri
This is not the Maddox but a discontinued model. If you new how little space there is on the Windstar you would know why I needed this tool. It was new in the box. All parts are accounted for.
K
Kenskip1
Missouri
If the Pittsburgh inner TR kit is successful at least once to complete your repair then you got a winner
Is this statement from personal experience or simply here say? Have you used this tool before?
For the price of it, I will gamble on it. I will give an unbiased opinion and not a lot of bull ****.
d.mcfarland
Western PA
I have it and have used it without any issues.
I suspect it is made by the same people who make multiple other brands at that price point.
Well worth $15. The inner tie rods are not high torque and they should be covered by the boot. Corrosion shouldn't be an issue so as long as the kit has the right size, you'll be fine.
Debcrow
New Mexico
A little possible warning.
I went to change an inner tie rod on my son's girlfriends Ford Focus. The factory OEM tie rod DID NOT have the flats on either side for the normal tie rod tool to work. Managed to get it off after removing things that were in the way and using a pipe wrench. Afterword I found out there is another tie rod tool for this application that uses a serrated U bolt type clamp that a socket wrench extension fits into.
You may want to remove the boot clamps and slide it back to see if it has the flats for your tool to work before getting all set up to change them and then be unable to remove them. You can use standard hose clamps to reseal the boot.
bwringer
Indianapolis
Same -- I have one of the cheap Pittsburgh tools, and it worked fine on a Toyota. The closest adapter in the kit wasn't an exact fit on the flats, but it was close enough to work just fine.
The newer Maddox version includes 12 adapters, and the Pittsburgh only seven. Otherwise, they're pretty much the same thing.
Ditchdigger
Eugene, Oregon
I went to buy the Pittsburgh tie rod tool last night but it did not include the 38mm adapter I require so I bought the Maddox. I will find out this afternoon how well it works but it is a decently machined part
cgrutt
I bought the Maddox had to open up one of the adapters with a file to make it fit but it did the job.
lolaetype
North Western Arkansas
That looks pretty much like the set I've "borrowed" for free from the auto parts store. That one worked just fine, so I'd expect the HF tool to also work.
tak1313
I got the HF tool some time ago (I think it was Pittsburgh branded at the time) to do my 2WD Ranger. It worked OK, except, at least for my Ranger's inner, it BARELY made the length. The insert could not entirely seat into the tool because of the length of the tie rod, so I was worried that it wouldn't be able to apply the necessary torque without "stripping" the notch, but it worked well enough for me to do the job.
K
Kenskip1
Missouri
Have a look at this.
Astro 78806 Inner Tie Rod Removal Set​
Looks identical to Harbor Freight to me.
Lisle's sells for $142 on Amazon
Ditchdigger
Eugene, Oregon
I just attempted to use the Maddox. It was a total failure. The "C" shaped inserts spread out and slipped at maybe 25ft/lbs.
I am going to attempt to return it, completely unusable.
ThePostman
Virginia
I went to change an inner tie rod on my son's girlfriends Ford Focus..... Managed to get it off after removing things that were in the way and using a pipe wrench. Afterword I found out there is another tie rod tool for this application that uses a serrated U bolt type clamp that a socket wrench extension fits into
This tool. It's not expensive, it's not big, and fits many vehicles. In an indie pro setting, it's the tool I reach for first to do most inner tie rods.
Mr_B
Reading
This tool is indeed cheap and pretty adaptable handy tool .
Have one in the tool box & it paid for itself instantly although that easy for a 10 buck tool .
For those in a pinch you can make a clamp from a decent quality exhaust u-bolt or for ones with flats a cut/ground open end wrench jaw with an old socket or extension female square drive welded on to take ratchet extensions breaker bar as needed .
WWheeler
Middleofnowhere USA
I have the older Pittsburgh set for at least 10 years now and I recently added the newer Maddox version. I needed the latter as the Pittsburgh set doesn't have the larger size I needed for a 4Runner, and the little u-clamp version wouldn't budge them. They both work well, **** the Maddox is a little beefier and has more adapter sizes.
K
Kenskip1
Missouri
So, after having all the needed items for a successful adventure of inner tie rod replacement, my Harbor freight tie rod tool worked exceptionally well. Not a problem except the new tie rod was stiff (insert pun) as a board. The job took a bit longer than I had anticipated however the driver side is next on the list. Summery, the $16 harbor Freight Tool gets a 5 Star rating in my book.
