My HF lift has a pointed set screw where the large shaft goes through the center triangular part. See picture. There are just a couple of threads so it falls out but does not seem to affect anything. Does anyone know exactly what it is supposed to do? Without disassembly, it looks like there is a solid shaft that goes all of the way through the end supports. There is then what looks like a long steel bush going all of the way through the triangular part. It looks like the pointed set screw could be intended to prevent the bush from rotating in the triangular part but I'm not sure why. Could it be there to ensure bush to shaft wear instead of bush to triangular part wear that could result in a lift failure. I'm not sure if I need to come up with a fix or not.
