twentythreemx
Hello,
I saw several posts when searching but many of them are old posts..
I'm hoping to maybe find someone with more RECENT experience (year or 2?) in case maybe they have changed the pump they use..
Just picked up one of the cheapo 20 gallon HF parts washers. Picked up a gallon of the yellow heavy duty degreaser they sell as well which has "decent" reviews. For what I'm doing (cleaning up some old motorcycle parts occasionaly and thats about it).. im sure any solution will be fine...
After reading though, some people say the water base stuff eats the paint up in the tank and will cause it to rust through pretty quick.. also tough on aluminum parts..
Lot of people said they run mineral spirits, kerosene or the tractor supply PSC1000.... but some people claim it ate up their pumps in just a few days or months... then you see people that said they have ran it in their HF tanks for 10+ years w/out issue. bad luck for those people or what?
Has HF changed to an even worse pump recently that cant handle the solvent based? i know the manual says to use water based but its a metal tank w/ a fusable lid.... seems to me like it should handle solvent.
Is the water stuff fine and not going to rust my tank out like some people say? The other dilema is its in a non heated barn and its currently like 9 degrees... solvent would be nice as it wont freeze...if i go water based.. I assume it will freeze (however cannot find confirmation!!!! any input there? figure i'll be diluting like 10 to 1)... then im looking to add some kind of heater to it if it will freeze (cant find info on SDS)
im over thinking something that should be very simple and just looking for someone to set me straight on the above, please!!!!!
Thanks in advance!!!!!
I also watched some videos people seem to be running solvents (and filtering good). But pumps do die according to many responders but I think the main reason is that they are just pretty cheap.
