Harbor Freight: Quality vs. junk
ThunderRolls
I buy from several places, but have in the past checked a thread here were various HF products were reviewed expressing views about which were quality and which were junk. I just reviews 18 pages with HF in the title and can't find the thread. Any help here?
driftpin
HFT has its place. I've got numerous HFT items, from portable bandsaws and their handy stand, for either vertical or horizontal cutting;
to a demo hammer/drill which paid for itself the first time I used it,
to a 4" orange-bodied side grinder/cut-off tool that is probably >25 years old and it still does the job.
I have a multi-process Vulcan OmniPro 120V/240V welder which I'm learning to use.
I have some back-up 3/8" & 1/2" socket sets, a kit of screwdrivers in slot, phillips, and Torx sizes; and lots of disposables/consumables, like flapper wheels, cut-off discs, grinding discs, and a 14" cut-off 120V tool. I found a 4 ft LED 120V light to be of much-use working in and under vehicles, it provides good lighting and it hasn't broken yet. I'm old-enough to recall working with incandescent bulbs in a 'drop-light extension cord' an aptly-named tool. Drop the lamp, and go retrieve the replacement incandescent bulb you have on stand-by for just such a failure of the broken filament.
Here's a HFT media blasting cabinet for which I made a base to convert it from a benchtop to a stand-alone. I also used fine stainless-steel mesh over the viewport to prevent it from etching so-quickly and it works well.
I have nearly-all my hand tools like sockets and wrenches, and ratchets, as USA Craftsman, S-K, and Wright, most bought last century. But I have gotten good use out of my HFT items.
willf650
Do you remember a time that Harbor Freight occasionally had name brand tools?
I have a 1/2 drive sk deep socket set from there as well a Chicago Pneumatic die grinder and I’m pretty sure my Ingersoll-Rand air hammer came from there.
I remember they aslo frequently had dewalt stuff but think that was reman stuff.
This was when they were a catalog and didn’t have all the physical stores.
BIGTOY44
East central Indiana
I have and 1/2 drive sk deep socket set from there as well a Chicago Pneumatic die grinder and I’m pretty sure my IngersolRand air hammer came from there.
I remember it well.
OccupantRJ
Eastern North Carolina
I have been buying from Harbor Freight since around the late 70’s when I found a small block ad in the rear of Popular Mechanics magazine with an 1-800 number to call. I called several times over a two week period before I got an answer. When I asked about a catalog I was told they only had printed sheets describing the various freight items in inventory at the time, which were actual shipping salvage items. I was mailed several sheets and I have been buying from them ever since. I wish now that I had held onto those early sheets to post pics of.
Steel_Rain
This was long before my time, but Wayback Machine agrees with you. A snapshot from 16 October 1997 (yes, that was 28ish years ago):
Kscardsfan
The Little Apple
Yep, similar to Northern. Mainly reman and closeout stuff seemed like, but I remember it from when I was a kid.
Kscardsfan
The Little Apple
If you look at some of the early stuff, it actually said Harbor Freight Tool and Salvage on them. We warrantied an early torque wrench when I worked there and I saw it and couldn't believe it. Nor could I believe it was made in S. Korea.
willf650
Yes, I remember they sold Quincy too but that was above my pay grade at the time.
Had a 30 gallon oilless craftsman at that time that I rebuilt 3 time before I finally sold it.
Air tools were about the only choice at the time for impacts but that’s not the case anymore. Still think air is the best option for die grinders though.
86turbodsl
i can add a fail item to this thread. I recently bought a 10pc knockout punch set, intended as a copy of greenlee punches. I usually use the 1/2 in knockout for my work. Failed first use, the cutting die shattered, and the bolt bent, as a result, the bearing also deformed. Utter junk and into the trash.
kbuhagiar
Escondido, CA
Why not return it? HF is usually pretty good on returns.
mreisner
North of Detroit
Before that it just said Harbor Freight Salvage. Damn I'm getting old.
