Harbor Freight Roto Ratchet
matthew
I'm kind of surprised it's not rougher underneath.
If you like it that way, use it that way A dab of vinyl tool dip (or brush-on electrical tape) would also be options if that's still not quite to your taste.
23 CHIEF
Buffalo NY
I was surprised as well it's almost like a chrome handle I am not a fan of the plastic handles much easier to keep chome clean and i prefer to feel
Sent from my SM-T560NU using The Garage Journal mobile app
cptn_zippy
Denver, Colorado
Go to HD and buy a Husky screwdriver and redrill the handle to a larger size. Boil and pop that sucker on there. I did that a couple of years ago with a craftsman pro driver, and now it’s one of my most used ratchets.
J
matthew
I like chrome handles on ratchets, but I've got the Gearwrench roto-ratchets and often use them like screwdrivers, or by spinning them by rubbing my hands together (so they quickly freewheel by inertia). For that I like a little bit of rubbery grip. I suspect I'd have hated the HF original grip, too, but at least for me I can see these particular ratchets sometimes benefiting from grippiness.
nbpt100
Massachusetts
I am not a fan of the HF Roto but if it works for you have at it. The price is right.
I like my VIP that has a flip out handle so you can use it like a T wrench and it has a locking head feature so when I do use it like a nut drier it does not slip.
Revere Cycles
Rochester, NY
I've long thought about replacing the oval handle on my HF ratchets with a more traditional hard handle from Mac or Snap On. Not because I want to hide the fact I have a HF ratchet, I just prefer the shape of other handles more.
toolmutt
Texas
This is what I did. Provides a great feel for spinning down a fastener then final tightening. I used a HF ratchet for an inexpensive "test" run. I like the concept but will upgrade from the course HF head soon.
Danglerb
SoCal
I like the HF roto ratchet, nicer handle goes in the whatever makes your boat float category.
mudflap
cincinnati,ohio
Lol...You could probably make a fortune on those at the flea market.
Rabid Badger
That makes me want to head to HF, grab all three swivel heads, a set of these and start swapping handles.
Mr_B
Reading
grind the tangs off and get some alloy pipe to epoxy over the handle stub, you can get original length back or increase it an inch or 2 .
If you got a lathe you can really make some nice fancy metal sleeves for these ratchets.
