I haven't tried this (yet) but it just came to me; if you envision EVER wanting/needing to "borrow" that jack for temporary use under a vehicle, you could make the "knob" from a piece of small square tube, pinned ACROSS the screw on the jack (a cross-bar, IOW) then graft a piece of the next size up tubing (with one of the 4 sides cut off, making a "U" channel) onto the original jack handle. (Open side OUT)
That way the air/hyd jack would still be "finger friendly", but you could reach it with the longer handle for under-vehicle use.
There's not a lot of "wiggle room" in that area, so the small tubing pieces would need to be the smallest that'd fit over the head of the pinned valve head; then 1 size bigger for the jack handle part.
IF you don't need that option, then by all means don't read this - it'll only slow ya down :=)) Steve
