Hey Fellas,
I just purchased the 40-lb blue HF Soda Blaster and I'm having some issues using it. I am finding that the soda does not flow out consistently. I have tried various pressures and adjusted the amount of soda flow and can't seem to fine tune it. Any tips? The only consistent flow I can get is when I set the pressure very high (~80psi) and turn the Soda amount all the way open...but it shoots it too rich and wastes a lot of soda!!! When I turn the Soda amount knob all the way down to the "-" position, a small amount of soda still comes out. It seems I cannot just flow air alone and then dial in the soda slowly. This is the one I have:
The other question I have is regarding HF's red blasting cabinet. I want to use soda in it. Instead of using alumina oxide or sand, could I simply replace it with soda and blast away? Or do I need a special rig to make it work inside? This is the cabinet I have:
