chrism1791
Couldnt find any at my local store to purchase. Really wanting to compare them to my bahco for fun.
Has anyone bought and put them through the paces yet??
typical HF QC issues or something in particular?I have two. Not impressed at all, but they were cheap.
I used them one time. I was using it to hold the piston on the shocks of my pickup trying to get the 21 year old, 157,000 mile nut off. It did the job, but it would have worked better with a regular pipe wrench. Since I had just bought the Swedish versions along with the 1/2" drive right angle impact specifically for this job, I refused to give in. I did use the other wrench for the other side just to see if the first pair was defective, nope. Both the same.typical HF QC issues or something in particular?
one more tool to scratch off the list there.I used them one time. I was using it to hold the piston on the shocks of my pickup trying to get the 21 year old, 157,000 mile nut off. It did the job, but it would have worked better with a regular pipe wrench. Since I had just bought the Swedish versions along with the 1/2" drive right angle impact specifically for this job, I refused to give in. I did use the other wrench for the other side just to see if the first pair was defective, nope. Both the same.
Why? Was it unable to clamp hard enough, or were the teeth too soft/dull? Are these pistons typically hard? Have you used others Swedish pipe wrenches (Snap-on, Bahco, Knipex, ...)?It did the job, but it would have worked better with a regular pipe wrench.
It would grab and hold the piston, but I had to squeeze the handles so hard my hand hurt. If I didn't, the piston would spin. Maybe the piston material is too hard for the teeth to get a bite? I don't have the answer to what was wrong. I have used the Snap On version (not mine) to run black iron pipe for an air line. Those are nice, effortless to use wrenches, but I wouldn't use them enough to justify the expense.Why? Was it unable to clamp hard enough, or were the teeth too soft/dull? Are these pistons typically hard? Have you used others Swedish pipe wrenches (Snap-on, Bahco, Knipex, ...)?
