Harbor Freight Tool box wheels
Wamsutta
Amarillo, Texas
Are those casters real Faultless casters or are they knock-offs?
The real Faultless casters will have a patent number and then say "Faultless" under the spring.
KenC
I have a 14 year old HF 44. The urethane band on the caster started breaking down. Found and exact replacement,wheel only, at Surplus Center. less than 10 bucks apiece. 5 minutes per corner to replace.
ChrisLS8
You clearly just messed up. What you should have done is spent weeks trying to sell it to CL lowballers then buy a much smaller cart at a much higher price. :wtf:
rpcraft
Waco
Pretty sure not but I will take a closer look and see. They look a lot like that but I think the dead give away is that there are no grease fittings on the wheel bolts or anywhere else. I entertained the idea of greasing the swivel bearings and the wheel bearings but found out after looking closer that there were no grease fittings and although I could take the wheel and bolt/axle out and resolve that I think that the swivel bearings won't have a provision that doesn't involve a needle or syringe type grease injector to get them into the swivel area.
Al Borland
I think you are all overthinking this.
These megaboxes don't normally get rolled all over the county. They are the stationary "main boxes" in the shop.
At the plants i go to on a regular basis, ANY toolbox that is rolled around a lot gets a frame under it and bigger/better casters. Usually the mobile boxes are of the 26"-32" variety. I see Matco, Husky, Waterloo, Kennedy, Craftsman and Montezuma boxes with this done. The casters usually are larger, with much bigger wheels to handle floor irregularities.
rpcraft
Waco
Considering the amount of work I have to do currently just to move it over two feet total I'd beg to differ, lol.
