Hardie backer board
1redTA
Pace FL
I am redoing the rotten siding on the other side of my house. I scored then snapped all the Hardie backer with a handheld razor knife on the first side. Please tell me of a good, cheap way to do this.
Thanks!
racecougar
Missouri
Scoring and snapping is the good, cheap way. Cement cutting blade in a circular saw is the next step up, but it isn't kind to your saw. Then there are saws specifically made for the job like the Rigid R3400...
cgrutt
If you're using a standard utility razor suggest investing in a carbide scoring tool it will hold up a lot longer. They also have 4 tooth backerboard blades for your circular saw but they throw off a ton of fine dust which makes a mess and isn't good for your lungs. Where eye pro and a respirator if you go that route.
Scoring tool:
Blade:
Hank11
Tennessee
You’re not really using Hardie backer for siding? Its made for tile substrate.
racecougar
Missouri
I'd venture a guess that the OP is doing stucco over it.
1redTA
Pace FL
I’m using Hardie backer siding to replace the old wood on the gables of my house, I guess I should have been more specific 🤷
lynnbilodeau
Oklahoma
Using Hardie plank I would guess. It isn't a "backer". It is siding already primed and ready for paint.
If you are doing a big job, get something like this.
That isn't the brand I bought, but something similar. Don't remember the brand name.
No dust. No scoring. I did have the correct blade for a circular saw on hand just in case there were some weird angle cuts. Barely needed to use it.
You DON'T want to breath much of the dust from using a circular saw or an angle grinder.
1redTA
Pace FL
between the Diablo Hardie blade I put on my old craftsman sliding mitre saw and the “free” DeWalt oscillating tool I got when I bought two new batteries I didn’t use more than one razor blade on my razor knife. I did however use most of the oscillating tool bits that came in the DeWalt kit for the tool. Man they go fast!
Hooked
League City, Texas
Wish I'd had one of these 15 years ago when wife and I did hardie siding on a weekender we had. I used my miter saw. ugh
Viper98912
GA
You'll chew through any oscillating bit or jig saw blades instantly; you need ones specifically made for fiber cement (and those will also get chewed up, but slower)
75gmck25
Alexandria, VA
I put a 10" cement board blade in my miter saw and used it to cut all the angles and straight cuts. I also used the cutting tool referenced in the Amazon link above, but found it took some time to understand how to use it. Looks simple, but you can still get some screwed up cuts.
Make sure you use a HEPA mask when cutting if you use a cement board blade in your saw. The dust it creates is a really high cancer risk.
Also check the Hardie site to determine how they want you to handle the middle joints between two horizontal pieces. When I did it they recommended using a piece of flashing (5" wide?) behind the ****-connection, and not using any caulk except at the ends where it met a trim board. Not caulking in the middle is different than what you do with other products.
There is also an alignment tool called a Gecko gauge that makes it really easy to hold the horizontal siding boards while you nail, and make uniform spacing.
endangeredspecies
I need to cut 1 single sheet of 96x48 Hardie Sierra (8” OC) siding down to 43x48.
Don’t have an angle grinder. Don’t want to drop $50 on a cement blade for a single cut, if I can help it.
Would the scoring tool in this thread benefit me?
Should I throw my cheapest all purpose blade into my saw, and throw it out when I’m done?
Would a laminate/aluminum blade work better and survive? Or would I still need to chuck it when done?
Skil Saw or Contractor “table” saw the preferred method?
Hank11
Tennessee
Strong hands and a clamped on straight edge and yes, you can cut it with a razor knife. Might need a couple of blades and a breather every once in a while.
Codyboy
S.E. TEXAS
My BIL has some nibblers he uses for hardie backer.
Looks like a drill with nibbler scissors.
But for a one time thing, just put on a dust mask, stay up wind and cut with a circular saw .
endangeredspecies
Just one 48" cut. I saved the Diablo laminate, rip, and cross-cut blades - put on a mask, and used the combo blade that came with the DeWalt DWE741. Made it all the way through, and seemed ready for more. So, very happy. Thanks guys!
