jtrux
I'm installing some Hardie lap siding and before I get too far I wanted to get opinions on attaching it directly to the studs or is it preferable to attach to OSB? I know both are acceptable but is one method better?
This!^^^OSB, Tyvek, and then Hardie. Nail it through the OSB to the studs; make sure you mark them out ahead of time. Use a siding nail gun and a good pressure regulator on your air line to get consistent nail drive without blowthrough or cracking. Use the flashing plates behind the joints, and only use factory primed ends on the joints. (Expensive, and takes some effort, but eliminates moisture/delamination and buckling problems later). Space with 1/8" gap and don't caulk. Bury all your cut ends on the corner or end trims, and caulk them with OSI Quad Max.
OSB it is.
As for not caulking the joints, why? I had anticipated flashing and caulking just because I figured the caulking would give a better finish.
OSB it is.
