Hardinge Grind All No. 1
fordsteel
small town Elkland PA
Harig Grind All No. 1
$350 shipped in the lower 48 obo will trade for tools or hot rod parts
Harig Grind all no.1 Light use and In perfect shape. will post pictures later. These cost well over $2,200 new for one not even made by a company as good as Harig. 3 inch center hight V block mount. For tangental grinding of any shape.
Hardened and ground tool steel with solid one piece construction
Preloaded ball and race design provides highest accuracy
V-Block adjusting screw allows for quick movement of v-block to +/- 0.0002 without tapping
360 degree graduated dial for convenience
24 division index plate with precision index pin locks in every 15 degrees to +/- 15 seconds
2 adjustable stops work with stop pin to set accurate angles between index locations
U-Clamp and screw secure piece part in v-block
Handwheel controls both rotation and offset movements
Tangent "throw" 9/16" to either side of center
Screws provided for locking slide plate off center
F
fordsteel
Bump With Pictures
kvom
*******, GA
That's a fairly specialized tool for use with a surface grinder.
I'd suggest listing at practicalmachinist.com.
