Finally getting around to wiring up my compressor. The current outlet location has a 14-50 receptacle. That will be coming out and the choice then is either Liquidtite or flexible metal conduit. I'm leaning forwards the Liquidtite. I use fmc in the past and it's awkward to work with in regards to cutting.
I am adding a Leviton 60 amp switch in a Leviton box on the front of the unit in the location where mag starters generally go. So starting at the wall, I will need a 2 gang cover plater with hole, 90 degree liquidtite elbow, liquidtite conduit, straight liquidtite connector. From this Leviton box, I need a straight connector, liquidtite conduit and then a 90 degree elbow into the back of the starter/pressure switch on the side of the compressors. I will likely run 4 wires from the wall into the 60a switch box in case I want to pull 120v power for a fan for the compressor at a later time. Total wire length is less than 12 feet.
I have a Quincy qt5 without the mag starter. The fla on the Baldor is 23a I believe.
http://www.aircompressorsdirect.com/Quincy-251CP80VCB-Air-Compressor/p856.html
Any suggestions on size of liquidtite conduit? 10 THHN qty 4 wire size? Any other thoughts?
Thanks for the help.
