Harry Epstein Tool Giveaway!
ChevyEFI
Phoenix, AZ
Tool & use:
Snap ring plier 9 1/2" - Tip .090 Straight # 535 $15.20
Mine with replaceable tips are sloppy and take several tries to work each time; I'm wanting to try a fixed-tip set.
24" HD Magnetic Tool Holder # AM-1 $11.00
I need organization; these should be a great start in a workbench area to keep specific tools out of the way and accessible.
Wilde Pry Bar 31" overall # 24B $11.50
This would come in handy separating gears and cases.
1" Wilde Pull Scraper # 516C.B $6.00
Cleanup of cases. And pull type seems more intuitive. (except when speaking of Valeo. If anyone gets that, quote me. :))
Nozzles - Hose # 528N $6.35 Ours corroded to a shutoff valve and another would be nice to use / waste less water.
7" Vise Grip Straight Jaw # 7R-USA $9.95
This is a "had some; they have walked away over the years" item that I could totally use. And yes, I chose USA on purpose.
Eteched Figures - Copper Square # SC-2C $12.05
I'd use this on an upcoming gate project. And I like materials and surfaces that stand out, so copper is a natural.
#2 Phillips 4" Blade - Screwdriver # 81593 $1.95
My Craftsman and Stanley #2 screwdrivers are distorted at the tip.
Total: $74 even. I like that you can get some genuinely good pricing from HJE.
frankush
IL
Very nice of you to do this Stuey. I'd love to have a nice Wetterling's wildlife axe #SAW 13H.
Farmall450
Marengo, Illinois
EdJack
516 1" Wilde Gasket Scraper $5.05
516W 1 1/2" Wilde 1 1/2" Wilde Gasket Scraper $6.00
516C.B 1" Wilde Pull Scraper $6.00
516S.B 1" Offset Gasket Scraper $6.25
24B Wilde Pry Bar 31" overall $11.50
28B Wilde 36" Pry Bar $14.85
444K Wilde Snap Ring Plier w/ Interchangeable tips $17.80
26 6" Channellock Pliers Slip Joint $7.40
TOTAL = $74.85
1973
I'm in!
Norseman #j-29 29pc drill bit set $60.30
Magnolia metal dust pan #901p $4.45
Pumpman1968
Upstate, NY
I would like the Williams stubby metric combo set order # WLMSTBY $50.00 and the Ridgid 9" Lineman's Pliers w/ Crimper order # 763 $17.50
rob1200
California
What a great idea!
Here's my wishlist:
3/8" Drive Armstrong Flex Ratchet #11-994 $58.85 link
3/8" Drive Metric Socket Holder. Billet Aluminum #38B-ST $15 link
Total: $73.85
tvfd911
I tried making a list but I can't keep it below $75. So- surprise me! (maybe with Wright ratchet(s) or a the big set of Wilde punches and chisels)
bofe954
1/4 inch armstrong 88 tooth $32
7 1/4 knipex cobra $28.70
can of hand wipes #72405 $12.80
fordzilla90
Awesome Idea!
Here's my list if I get the luck of the draw.
#7116-4R Products Engineering 12” 4pc Combination Square - $48
#20911 9 pc Folding Pocket Style Allen Set 5/64”-1/4” - $4.90
#21151 5 pc Folding Pocket style Allen set Metric - $7.35
#842 General Die Cast 9” compass - $4.25
#12FP Xtra 12” flex Spout - $4.45
#LT9 Ultra Lube Matal Cutting Lubricant – Qty 2 - $4.60
Total - $73.55
91bronc300
Sweet :) I'll cast my lot for:
C150 3lbs copper hammer
C125 2lbs copper hammer
and a 30 inch BAHCO Ergo Bow Saw if they can order it, if not, then a few CB134 bearings to make up the difference.
-Brent-
Utah
Thanks to you and H.E. for the opportunity. On my wishlist, I'd love to try out the ARMSTRONG #11-992 88 tooth Aerospace Ratchet.
offroadford4x4
York County, Pa.
:beer:
qty2 – Wilde 36″ Pry Bar # 28B $14.85 $29.70
qty2 – Wilde Pry Bar 25″ # 18B $10.05 $20.10
qty2 – Wilde Pry Bar 17″ # 12B $7.35 $14.70
#1 Phillips x 3″ Blade -Screwdriver # P331 $2.50 $2.50
#2 Phillips x 4″ Blade – Screwdriver # P442 $3.55 $3.55
#3 Phillips x 6″ Blade – Screwdriver # P653 $4.35 $4.35
Subtotal
$74.90
Very generous offers! thanks Stuey and HJE!
I'd probably go for the Williams stubby metrics and some 3-1/2" cup brushes.
STGFordCrazy04
St. George, SC
Wilde 12" pry bar #7b
17" prybar #12b
25" prybar #18b
31" prybar #24b
36" prybar #28b
Channel lock #E348 linesman pliers
Total =$69.60
Thank you for the opportunity
ArkTinkerer
High Speed Norseman Tap and Drill Bit Set
Would be great to have high quality taps and matching drills in ONE place!
cdrewferd
Westminster, CO
This is a great give-away. Thanks for the opportunity.
I would honestly go for a bit of everything. A 4 pound Estwing sledge, a pair of pliers, a good face shield, and probably some decent screwdrivers.
mattmus4357
Land of Oz
I would wish for:
S2-C2 Copper Square $12.05
1430C 3" C Clamps $3.45 x 2 pcs
1460C 6" C Clamps $7.80 x 2 pcs
436 6" Channellock Cutting Box Joint $13.40
D-13 Norseman 13pc Drill Bit Set $25.85
Total of $73.80.
I will be starting a DIY teardrop camper in January and these are all items that will help me complete that build. Come on, help a young, broke guy finish out a proper tool kit :thumbup:
filtered
Berks Co. PA
Thanks for the giveaway!
10-992 1/4" Drive Aerospace Armstrong Ratchet 88 tooth $32.00
11-992 3/8" Drive Armstrong Aerospace Ratchet 88 tooth $37.50
$69.50
