has anyone painted their black pipe?
jonese
SC
I was just assembling the airlines for my garage and must admit I'm not too excited about hanging them in their current condition. They're the black pipe from Lowe's. They don't look terrible but there are dings and scuffs and some rusty spots already. I keep telling myself this is just a garage and not my kitchen but then again some people's garages on here are nicer than my kitchen. I want something in between. I don't want to put a ton of time into it but I'd like them to look a little better than they do now. So before I hang these pipes, I was thinking about cleaning them and then putting a coat of rustoleum on them. Anyone tried this? Would the paint stick?
chickenhauler
Pennsylvania
I rattle canned my gas lines when I ran them, and plan on doing the same to my air lines. I didn't bother with much prep or primer since they'll be up and out of the way.
haugy
Nashville, TN
Do a little prep to remove any oil so the paint adheres well.
Air lines will condensate in the summer with cold air moving through them, then hot, etc
So you want to make sure the paint will hold against moisture.
J
jonese
SC
Cool, thanks guys. I know they come with some kind of coating on them because my hands always feel grimy after handling them. I'll clean them with some brake cleaner or something and maybe knock the rusty spots down with some sand paper or something. Shouldn't take more than an hour for prep and paint for the small section I'm doing. Now I need to decide if I want to redo them in black or something else.
Shadowdog500
Down the shore
Funny, I was talking about this earlier today.
About 30 years ago my dad painted all of the black iron gas lines in our basement with flat black Rustolium using a brush. It still looks good today. I may do this with the pipe after I run the shop air.
Here is a link that has pipe identification color codes.
http://www.labsafety.com/refinfo/ezfacts/ezf203.htm
Chris
Jim in Wis
Sheboygan Falls, Wis
Years ago, all the pipes in a machine shop were supposed to be painted different colors, water one color, air another, gas another, etc. I sure don't remember what colors were what.
The candy cane look would be good, make sure you get the stripes nice and even though.
jam022316
Indiana
You guys ****. Just one more idea I've got to do now! I don't have mine up yet, is it wise to paint before or after you hang them up. There may be some touchup to be done around the joints but surely it'd be easier to paint while down.
PurdueSD
Indiana
Here are mine... I painted them after assembing, just took them apart at the unions. Alot of extra work really!
J
jonese
SC
My lines are going across two walls. I've got each wall section completely assembled and ready to be hung. Those pipe wrenches do a number on the pipes so I wouldn't paint them until they're assembled. I'll have to touch up the area where I attach the two sections once they're hung but better one section than eight.
As far as color, I was thinking of doing them blue to match my Goodyear hose reels. I really like blue in a garage, seems more industrial or something. I may do yellow though since the hoses are yellow and apparently that's the proper color for air lines.
J
jonese
SC
PurdueSD: what type of paint did you use? Brush it on or sprayed it? Primed it first?
Shawn F.
North Carolina
I have fire sprinkler system in my shop that is pretty darn old but still in service/use and the pipes are black (never painted, just how they came). I was thinking about painting them red since I am painting the entire shop this weekend (white floors and walls) and I think red fire sprinkler pipe would be fine but what about the markings on the pipe that are painted on in white or whatever color? Can I paint over these and be fine? I want everything to be in code and would hate to paint over the lettering and it not be in code after the fact...
PCO6
Newmarket, Ontario
^^^ I painted mine gray too. Before I installed them I wiped the pipes down with acetone, primed them and then rattle canned them with gray Tremclad enamel. After I installed them I touched the joints up with a brush.
Rag Roc
Central Florida
Wiped mine down with acetone, and brush painted the 10' lengths on saw horses with Rustoleum enamel. I wiped down all the fittings and installed them bare. Once completed I touched everything up with a small brush.
J
jonese
SC
Seems like a lot of guys have painted their pipes. It's good to know I'm not nuts, or I'm surrounded by others who are equally nuts. Either ways fine with me.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
no problems...when black pipe is used for gas lines it normally painted grey[/QUOTE
natual gas or propane is yellow. grey is not used to id pipe.
Trbo is correct. We recently had to redo our pipes in the shop to make them easily identifiable.
Here is a chart specifying pipe color codes http://pipelabeling.com/pipe_marking_colors.html
Steevo
43.49600, -112.04300
. . . . I'm surrounded by others who are equally nuts. . . .
^^^ This
:lol_hitti
I am NOT taking my air lines down and painting them, nor am I going to mask and spray them, brush them or do any other kind of finish to them. I need to get done working ON the shop and start working IN the shop.
Your painted lines all look real nice though.
RAYJAY
UNION DALE PA
^^^ This
:lol_hitti
STEEVO USE THE HAMERMILL PAINT VERY LITTLE WORK FOR HOW GOOD IT LOOKS :rocker:
j
